ezrun 9t problem
ezrun 9t problem
I have an ezrun 9t set-up. The problem is I can't set up the throttle correctly. I just touch the throttle and the car is spinning out. It's like a light switch off or on. I can't roll into it. I tried about everything I can think of. Anyone else with the same problem?
first of all, this is in the wrong section. It should be in the radio + electronics section
Have you tried setting it up again? It sounds like the ESC is interpreting a tiny bit of throttle as full throttle. I don't know how to set up the throttle endpoints, but it'll be in the manual.
