DuraTrax Foam Tire/Wheel Mounted Front & Rear Green F1 (4)
This is the Mounted & Trued Front and Rear Tire/Wheel set for the Duratrax DELPHI INDY racing car. These tires will also fit the Tamiya F103 car. These are brand new, never mounted.
FEATURES:
GREEN (medium) compound foam.
Molded black composite six spoke rims are rib reinforced for less flex giving, more consistant handling.
Tires are pre-mounted and trued, ready to bolt on and use.
INCLUDES: Four mounted and trued tires and wheels.
REQUIRES:
Mounting to vehicle
If needed, 5x8 ball bearings to be inserted into front wheel (DTXC1523).
SPECS:
Front
Overall Diameter: 59mm (2.32")
Wheel(rim) Diameter: 36mm (1.417")
Width: 30mm (1.18")
Bearing insert diameter: 8mm (0.315")
Rear
Width: 45mm (1.77")
Wheel hex size, for Delphi/Indy rear hex washer: 14mm (.551")
The stock hard plastic tires on the Delphi are virtually worthless. You have to use a foam tire such as these to get great traction.
These retail for $32.50 at TH. I am asking $20 shipped to your door CONUS. PayPal accepted.
FEATURES:
REQUIRES:
Mounting to vehicle
SPECS:
Front
Width: 30mm (1.18")
Rear
Width: 45mm (1.77")
ttt
