View Poll Results: What is your Favorite Airbrush?
Multiple Choice Poll. Voters: 1254. You may not vote on this poll
YOUR FAVORITE AIRBRUSH
#136
I bought the Iwata HP-BCS. Being that this is my first brush I didn't want to spend a great deal, but also wanted to get something that I was going to be happy with. I think I paid 90 bucks for it, have painted about 10 little toy car bodies, and even have done some work on the Big car with no problems. Someone had said earlier that the gravity feeds are better for getting into tight places, I couldn’t agree more. That’s the only issue I have about the BCS is the fact that you have a jar hanging off the bottom. But if getting into tight places isn't a big deal then I'd say the BCS would be great for anything you might need.
BTW, like the avatar.
#137
Iwata
Hi all,
where can i found IWATA products in Hong Kong ?
thank's
thank's
#138
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I owned 2 Badger airbrushes for years. After seeing what guys were doing with the Iwata brand I decided to switch. Wow! What a difference! I'll never use anything else.
#139
I have a knock off and 2 Badger 150's and could not get faskolor to spray properly.
i purchased my Iwata eclipse HP-CS yesterday and guess what? i sprayed faskolor out the bottle without thinning for the first time.
with the exhange rate in my country it worked out to $170 more or less.
Iwata gets my vote.
Iwata gets my vote.
#140
Thayer and Chandler Vega 2000, siphon feed, awesome action. I think Badger owns them now, but I have been using the thing for 10+ years now. awesome airbrush on a budget.
http://www.dixieart.com/Badger_Thaye..._Airbrush.html
#141
yea, have to go with te Iwata's myself....
pretty good...but there are alot of other ones that are good too...
the Revolotion series and Eclipse series are pretty good if your just getting into it and want the basics..
easy to clean,and repair "If" something goes wrong...
custom Microns may be some serious "Overkill" if starting out..but then will depend on the type of Jobs or "hobby" painting one will do...
i tell our students if they "Can" to put the airbrush in there hands if there able to...this way there able to find out better if it fits "Them"...sometimes you can have the Best equipment? but if it doesnt feel right for you you may not be happy....or "Comfortable" working with what ever airbrush you use...some things some may paint can take "Hours" if your not Comfortable..??..it can be a little discouraging.....
when the Mediums (paints) are properly thined for the aplication there used for almost any airbrush will yeild some killer results in the right hands....
but some will work "Easier" for some than others....
but if you can try a few in "Your Hands"....
if not
may want to be able to think about, can i get parts quickly if something "happens" to go wrong or a part breaks?
even 5 or 10 years down the road .....
what kinds of Mediums (paints) can i use with this airbrush..??
Water based? solvent based? "Both"...???
is it best for the things i will do...???
just some stuff hope it can help to find an "Airbrush" your looking for....
if not
#142
I am wanting to get an airbrush and get away from rattle cans. I found these two airbrushes and was wondering which one is better. The Paasche has the exposed area in the handle to easily pull back the needle to unclog it, is that enough of a feature to get the Paasche over the Iwata? I am not going to be spraying many fine lines or intricate detail, just want a good reliable gun to spray simple designs on a body.
http://www3.towerhobbies.com/cgi-bin...4&I=LXTXY1&P=K
http://www3.towerhobbies.com/cgi-bin...4&I=LXDD41&P=K
I was also thinking of using the Parma adapter to feed right from the bottle of Faskolor, pros, cons?
http://www3.towerhobbies.com/cgi-bin...4&I=LXZR30&P=K
Or is this gravity fed gun better?
http://www3.towerhobbies.com/cgi-bin...4&I=LXTXY4&P=K
Thanks in advance,
Steve
Thanks in advance,
Steve
#143
hey guys, im looking to get into the air brushing. Any ideas on which airbrush I should start out with?? I have no expirence, but would be a good hobby to pick up.
#144
Thanks in advance,
Steve
Thanks in advance,
Steve
#146
Ok Thanks, whats the best site to look for one. Ive already checked out tower. are there any others?
#147
Does anyone know what needle comes with the Iwata-CS (gravity fed) brush? I would really like to give the fascolor stuff another try, but have had no succes with my pasche or the testors aztec brushes. Any help would be greatly apprciated.
