fascolor tips
Be sure you are totally drunk when you paint, that way the result looks REALLY good.
Actually, just take your time and use common sense.
HAHAHA the state of mind is criticle.
I have found some colors work well with no thinning, and others with thinning. But do take your time.
read thie tread and do a search on faskolor techniques theirs alot of good info in the board read read read then read some more then ask ask ask and ask some more
this is a good site for info also
http://www.airbrushtechnique.com/vba/cmps_index.php
That is very true, it seems that the darker the color, the thicker it is.
also found the best for thinning is windex just my .02
Originally Posted by scoobydo
The window cleaner windex?
never heard of that.
I've heard of people doing that, but I don't see the point. With paint, I can't see how adding more chemicals is a good thing.
faskolor
Bought and used faskolor red and have been disappionted with the results. The red colour is very flat and dull. What colour/colours could i mix with the red to brightern it up and make future bodyshells stand out from the crowd.
To dull a color, mix in the contrasting color; for red, use green.
To brighten a color, mix in the complimentary color; for red, use orange or yellow.
Get yourself a copy of a color wheel, they are good tools to have.
problem with faskoat
Hi guys,
I've been doing airbrushing for a while, and I'm still fresh in certain areas & technics in painting r/c bodies. I'll like to take this opportunity to thank EVERYONE for their tips & comments that I have pick from them...... thank you.
Lately I've encounter a problem with 'Faskoat'. I have no problem with all my fascolor except for Faskoat. The 1st bottle i've own dried up after 20% of useage. Thinking I've left the cap loose, I have no choice but to buy a new bottle. Now it start to dry up again (20% of useage)!!!When I squeeze it out, it looks like toothpaste....but after I have thin it with water, it looks like glue with lots of bubbles.... and it is very difficult to spary, and often clogged my 0.5mm nozzle. Does anyone came across this before???
What should i do??? Pls HELP.....
Btw, the cap on the bottle is tight.
Thanks for your comments & help.....
Cheers.....
Cheers.....
FasKoat is a bitch to deal with. It dries very fast, though I haven't had mine dry in the bottle...
You have to use it to spray FasGlitter, and that sucks. The glitter settles to the bottom of the cup too fast, and the Koat dries in the brush. Just have to be careful, and ready to tear down your brush.
Wow! seems like everyone had bad experience with Faskoat!
I have not use it with fasglitter, only use to Fuel proof my shells & glue maz. cut out...
Now I have to store it in the fridge (not the freezer), do you guys think will help????
