liquid paint mask which one is the best??
I know Parma makes one and bob divleys which one is better?? and are you spraying it on or brushing it on?? how much you thinning it?? I have always used painters tape or the yellow sheets when doing designs on bodies. but after doing that for about 20 years it's time to try something else. Thanks
1. RCS
2. Bitty
3. Faskolor
RCS is the best for me, sprays awesome, peels away awesome, and not to exspensive. Bitty stinks, smells like sh*t. Works very good though. Faskolor, I don't like it allot. Works ok, but way to thick to spray out of the bottle.
I only think a RCS bottle with like 1cm extra of water and good shaking. Spraying with a spray gun with 1.5mm tip @3-4 bar. Works very good. 3 layers and you're good.
After some advice from RCS I started spraying their mask on using a 1.5mm nozzle cheap EBay spray gun, 2 nice coats and the mask is done and dusted.
I tried 3 coats but found that the mask was so thick it was becoming tricky to cut!
I used a 10% thinned variant through a touch up gun (.8mm) but found that the final mask was unreliable.
I have used the Dively, Bitty and Fasmask. The bitty I got was chucky and had to be strained to be sprayed thou it did cut nice and over all was a nice product. Dively is thinner than the other two and takes more coats, I have had more trouble with cuts healing with this product than the other two. I use Fasmask the most "I get a better deal on it" It covers good with 2 coats sprayed, cuts nice.
I would rate them like this
1. bitty (if it was not chunky)
2. fasmask
3. dively
I have not used RCS, thou there candy paint is the best I have used, if there mask is on the same level it will be hard to beat.
2. fasmask
3. dively
