nitro body backing
nitro body backing
I'm using faskolor/createx to spray for colors but what should I use to protect the body
Rust-o-leum enamal... not the high performance stuff, just the regular kind. Clear, white or black work. I mostly use the white...
Wait till at least the next morning after letting Faskolor cure before you spray it, just to be safe. I have done it sooner, though, without any kind of reaction.
Thanks for the reply
After painting for a while I still haven't really settled on a backer. I find myself sealing lexan depending on the weather and the application.
If it's sunny outside and you're using nitro: I use rustoleum crystal clear or truck bed liner. The truck bed liner is cool in the fact it actually fuses itself to the paint (melts) and I can usually make the bedliner stuff lighter in weight because I need less to be happy with appearance of the seal.
If it's rainy I usually hold off on sealing nitro bodies but have a few people that actually prefer Faskolor Faskote. I swear about 2011 the stuff used to be much harder and bulletproof back then. They had to have changed the formula because it doesn't get rock hard anymore...now it cures more like epoxy tacky.
I`m also looking for a backer. I have tried Transparant Base from autoair. It only works for 90% and you have to make a very thick layer, so i`m searching. Unfortunately rustoleum truck bed liner is not for sale in the netherlands and the shipping cost from America to the Netherlands are unreal.
Thanks Chris, i'll ask Jon.
Spazstix needs to be backed with faskoat or something else prior to rustoleum. Its a bit of a pain and with the chrome "can", not always, fog it a little
I have backed Spaz Stix with clear rustoleum without issue. I would wait 24 hours for sure, before backing, to make sure Spaz Stix is fully cured.
