masking tape or liquid mask?
What tape would you guys use or liquid mask, Im not very good with my airbrush but im gonna go for it on this body
I use both the blue painter's tape found at home depot, and liquid mask if I'm doing more intricate work in hard to mask areas. Liquid mask gives cleaner lines, but I find the overall time investment cut in half if you use masking tape. Regardless of the method you choose, make sure that you have sharp x-acto or razor blades handy - you'll need them for cutting out your designs.
Depends on how detailed you want your paint job. Tape is great to cover big areas quickly and way cheaper than mask but you can't cut in the same level of detail that you can with mask. Tape can easily yield clean crisp lines. This is actually a can paint job masked with 30 cents worth of tape rather than $5 worth of mask.
[IMG][/IMG]
[IMG][/IMG]
Guys
Watched a lot of videos about applying liquid mask. However, they never say what pressure to apply to the hobby knife to make a suitable cut. What's the suggestion.
While I can understand that apply masking tape over the length of the body shell can be hard to produce straight lines but isn't cutting a line using a knife even harder?
Got a Blitz 1/8 GT body to paint but want to do some stripes like the advertised shell design but the last time I sprayed a shell was over 15 years ago and that was a single color Tamiya Subaru Imprezza. Any tips?
Cheers
Etops
Cheers
Etops
Guys
Cheers
Etops
Cheers
Etops
As far as pressure goes...there's no psi amount or anything. Just be sure you're not pressing wicked hard on the plastic. After a while making a straight line is fairly easy with liquid mask especially if you practice holding the butt of the xacto blade and dragging it in the liquid mask at an acute angle.
I'm working on slot car bodies that are made of .010 thick lexan. Is it possible to use liquid mask? I'm afraid I will cut the body when cutting out the patterns.
In my overall opinion, I would definitely choose liquid mask. Best of luck to you painting bodies!
