Body Mounting
Body Mounting
I didn't see a thread for mounting bodies, and it seemed to fit here. Fire away!
Anyone else find that the wheel well cutouts on their body dont match their car? Ive got a mazda 6 Im trying to mount on a TC4, and the wheel wells on the body dont match the car. I can get fron or rear matched, but then the other side is off enough so if I cut the holes where they ned to be to fit I have gone outside of even teh fender flare a bit. I guess the solution is "get a body that fits better"
That is normal, dont worry about it unless you are just a perfectionist. Most body shells have wheel outlines and they are never right. Stick with the Mazda it is an excellent body.
Yeh, It depends what wheelbase you run as well.
You surely weren't considering changing your wheelbase in order to have your shell fit better??!!
I would much rather have the car handling how I want it than have the wheels fit perfectly in the arches. I can't even tell from a distance that the arches aren't where the shell is moulded for them to be.
Just my 2c
Just my 2c
Position the front wheels centered in the moldings and then cut the rear wheels where they come.
