Advice on a Air Brush Kit
#17
if you use Spaz Stix and Pactra,make sure you have PLENTY of ventilation as these are laquer paints, if you use faskolor and createx ,make sure you have plenty of ventilation but faskolor/createx are non toxic but still you want ventilation...i even wear a paper dust mask just in case,lol
some people use the faskolor/createx straight, i cut mine with a little req windex....fill your cup a little and give one or 2 sprays of windex real quick,put cap ob cup n give it a quick shake this works for me use windex n water to clean between colors..this is for using water based paints,acrylics
if you use spazstix or pacra you r goona have to use laquar thinner n it smells
I am using createx colors and to make sure I am understanding this correctly I add my color to the gravity feed and then spray in two squirts of Windex and shake then spray?
