RCS paint stock here in the US
#62
Finally got around to trying out the RCS line, its sprays very well, I can see why some painters only use solvent paint, its much easier to manage than waterbased, too bad it smells! What is everyone using to back the candy colors with? I tried red backed with faschrome and then fasilver, It's very sparkly, but not very "deep". I like the look of the one backed with aluminum base, any chance of getting some of that on your next order chris?
The chrome sprayed and layered exactly the same as the spaz I was using, good stuff.
Thanks for bringing this stuff in Chris.
#63
Glad that your liking the RCS line Mike. Its a great paint line and I'm happy to be working with Jon to make it avalilible to painters here in the U.S. The Aluminum base is an Auto Air paint and comes in three forms, corse(think bass boat flake), medium, and fine. I use the fine and corse alot myself thay look great backing up the candys but each gives a different effect. Very sparkly for the corse and smooth but slightly subduded for the fine; I'll check into adding that to the site as well. For a really deep backer use the chrome, that adds tons of depth.
Jon is working on filling my next order right now which includes more colors and some of his stencils, I'll update the thread just as soon as those products are avalilible. I also did a slight redesign of the site, trying out a new look and added pics of the paint; much needed. While doing so I found that the canned program was not calculating the priority rates correctly each time, I have that sorted out now sorry everyone for not seeing that sooner.
Thanks to everyone that has ordered, I know that you have choices and your support is greatly appreciated.
Chris
Chris
#66
Hey Mike, it does smell being a solvent based paint but nowhere near as much as other known brands..
Looks like you didn't apply very much. Candies build in color/effect the more you apply.
Regards,
Jon
Regards,
Jon
#68
Super quick, from order to delivery! Thanks Chris! Can't wait to shoot some chrome today.
#69
It really depends on how deep you want the color, as a general rule 5 to 6 mabey more if thay are very light coats. I once layed down 10 coats total to get the depth and effect I wanted with a blue using the AA to back with, 9 coats of candy, and a silver backer. IT does take abit longer to lay down multiple coats as you need to allow for curing time; you dont want to trap the solvents under layers as that can cause some issues. But the final effect was really nice.
#71
I laid down four coats. Each coat was coaxed into drying with a hairdryer. After cooling, the next coat and so on.
I backed it with black and the results are pretty good! Weird how you can look right through it then back it with black and it is shiny. I wonder what a white backer would do - would it pop more? Does it show the same difference when backing silver with white or black?
Either way, this stuff is great! Thanks again for bring this to the states for us - Will be ordering some more colors very soon!
#73
Love the pics ;Dave is correct anytime I've seen chrome backed with white or silver the effect is a duller and more washed out look. For best chrome-like reflectivity use a thin coat of WB black and try not to use the blowdryer. For some reason that I cannot explain heat can dull the chrome also, not always but often. Just let each coat flash off for 15 mins.
#74
