Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Old 02-19-2012, 06:16 PM   #1
beedee's Avatar
Questions?? quick question regarding striping along windows
please excuse the forthcoming nOOb question.
do you guys just use a paint marker to do these? and do you do them on the inside of the body? do you just pretty much trace the scoring line in the body of the window with the marker?
i want to do the stripe on my bulldog body, just like the one below, but instead of yellow, i'll be using black. (my body is painted solid fluorescent pink)
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 02-19-2012, 06:57 PM   #2
Sk3tch's Avatar
Send a message via Yahoo to Sk3tch
I can pretty much guarantee that's a painted on line inside the shell by airbrush or spray can...not marker.
Take the window masks that comes with the body and apply it where it is supposed to go. Then take an Xacto knife and cut a parallel line on the inside of the mask and peel thin thin line (or what would look like trim) away- and spray it the color you want.
Does that make sense?
www.OTHGFX.com Off-the-Hwal GraFiX
Sk3tch is offline   Reply With Quote
Old 02-19-2012, 10:12 PM   #3
beedee's Avatar
thanks sk3tch. it does make sense, the crappy thing is, i already tossed the window masks.
ASSOCIATED ★
Old 02-20-2012, 03:23 AM   #4
One tip on using black for the window trim is that it will not be that noticible against the dark windows. I have tried it in the past and always regretted using black. Typically a lighter color looks best on the windows to contrast the darker color of the clear window.
markarch is offline   Reply With Quote
Old 02-20-2012, 03:28 AM   #5
savagesam's Avatar
Done this myself and then thought wish i had done a window border, so just using thin tape mask the lines and window infill and paint away then back it and peel the tape out and your good to go.
In regards to black I have also added another colour inside the black to high light the black being there because it can get lost in the windows sometimes, so maybe try a two border window trim, looks awsome when finished.
Good Luck.
- Australian Team Tekno Rc - The Nitro Shop - Nitro X Fuel -
- Proline - Coast 2 Coast Rc - Hearns Hobbies - SMC - Futaba -
- Sam's Youtube Channel - http://www.youtube.com/savagexsam -
savagesam is offline   Reply With Quote
Old 02-20-2012, 10:06 PM   #6
beedee's Avatar
thanks for the tips and pointers fellas. i think i'll go for silver, it should look good, ties in with the metallic in the b4.1 decals im using.
ASSOCIATED ★
Old 02-21-2012, 04:02 AM   #7
Bfutura15's Avatar
Tell me what the body number is? I might have some already made if interested. I have a few Bulldog templates, just matnot be for this one. Every body I paint I make a file of the window masks for I can cut again later.
Website: www.arrowgrafix.net (under construction)
Email: [email protected]
Bfutura15 is offline   Reply With Quote
Old 02-21-2012, 09:23 AM   #8
I use black window trims a fair bit and quite like the low key look but I also think white works really well as a trim.
U1timate PigDog is offline   Reply With Quote
Old 02-21-2012, 02:04 PM   #9
beedee's Avatar
pm sent!
ASSOCIATED ★
