Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Old 02-16-2012, 07:43 AM   #1
zeroack's Avatar
Default Cheapest way to practice?
What's the cheapest way to practice on a something that would simulate a lexan shell? I haven't tried glass. I'm guessing I could paint glass and then just put it tray of thinner to remove it and then start again. I just wasn't sure if the adhesion would be the same.
Digital Toast
zeroack is offline   Reply With Quote
Old 02-16-2012, 07:58 AM   #2
J. Schwarz's Avatar
Trader Rating: 49 (100%+)
2-liter soda bottles....empty of course!!
J. Schwarz is offline   Reply With Quote
Old 02-16-2012, 08:04 AM   #3
I usually use transparent A4 sheet. It is not really lexan, but close enough.
good for testing color schemes or color backing....
chobin is offline   Reply With Quote
Old 02-16-2012, 08:04 AM   #4
Colors_By_Dave's Avatar
Trader Rating: 84 (100%+)
Transparencie (sp) sheets that you can get at the office supply store for about a 20 cents a piece.
http://www.officemax.com/office-supp...oduct-ARS25666
Or the document pockets work also. Just cut them apart and you get two pieces to play with.
I also grab even piece of clear packaging material I come across for test scraps.
I save all the trim edges from bodies I paint.
I find you can get a lot of practice on plain paper.
So much of what you need to do for RC is based on paintflow and trigger control, you can practice that on anything.
I save all of my trash 8.5x11 paper from work, and use the backs for practice and test sprays.
The only downside of practice on paper versus lexan, is that the paint doesn't "push around" from the air on paper like it does on lexan, so it fools you. You can paint fine lines on paper that you never could on lexan.
Got Paint? Got MicroHoles? Got custom masks?
Colors By Dave - I love to paint
Colors_By_Dave is offline   Reply With Quote
Old 02-16-2012, 08:43 AM   #5
+1 on the transparancies.
I try out new techniques on them all the time. I usually do smaller squares masked off with tape and compare different techniques side by side to help me decide which is a better effect. I have even done side and top views of actual paintjobs on them and sent them to customers for review and approval prior to starting the actual body.
markarch is offline   Reply With Quote
Old 02-16-2012, 09:51 AM   #6
W.E.D.Jim's Avatar
Trader Rating: 16 (94%+)
Send a message via AIM to W.E.D.Jim
Maybe only me, but I think the cheapest way to practice is to use your race bodies and try things that are in your skill level. Gradually increase the work level as your skill improves.
This way you are not wasting materials practicing, like paint, blades, liquid mask and so on.
Jim
W.E.D.
www.wedjim.com
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 02-16-2012, 10:56 AM   #7
zeroack's Avatar
Brush control and all is great on just plain paper, I was thing more of masking and different paint combo's with different backings etc.. Like the license plates I use to use way back when except a see thru equivalent.
I use to use all my scraps to test on. I wouldn't have a bit of unpainted lexan around. I like the pop bottle idea.
Zero
Digital Toast
Old 02-20-2012, 03:40 PM   #8
Trader Rating: 91 (100%+)
If you end up using glass you don't need to use thinner to clean for reuse, you can just scrape it off with a razor blade (windex helps here), it will not scratch the glass. I've used lexan scraps and soda bottles.
Eric Tomczyk is offline   Reply With Quote
I want to race! Please help a newbie! THEPISTONHEAD Electric Off-Road 19 10-28-2010 09:53 PM
How High-End Do We Need Our Equipment To Be Competitive ??? Tpg racer Electric On-Road 43 09-26-2007 10:09 AM
Manufactures Agree To Limited Selection Of Tires For Electric Offroad Nationals Todd Hodge Electric Off-Road 95 08-06-2006 08:13 AM
