Circle cutter - yes/no?
Yep totally agree with Dave, I do alot of touring car bodies and cut every one with a circle cutter, in my opinion it gives a much better finish, as Dave said its not to cut the wheel area out, you just score it and peel. Works perfect in my opinion, definately worth the money
I got mine cheaper from a hobby/ craft store.
if the body is flat it will work, I've had problems when there is contours, or the body flexing and the the beginning and the end of the cut don't intersect. I now cut donuts out of vinyl stick them one and cut around the vinyl as a guideline.
