Airbrush problem
Airbrush problem
I just started airbrushing about a month a go. When I told a friend that I was airbrushing he told me that he had a box filled with paint and "stuff". When I got the box the "stuff" was about 30 bottles of paint (most never open or almost full) a small airbrush compressor and an airbrush: Iwata HP Cplus. Needless to say I was pretty excited. Who ever used the brush didn't clean it very well (my friend got the box from someone who just wanted to get rid of it) So I cleaned it out and ran some paint thru it.
The problem I'm having it the paint doesn't come out all the time. sometimes it's really light and then really heavy. I tried different paint and psi and it didn't change anything. When I run water or cleaner it works just fine. I did find that the neeedle has a small bend at the end. I've got a new one coming.
Anyone have any suggestions on what might wrong?? I know this is a quality brush so I'd really like to get it up and running.
Thanks in advance and sorry for the really long post
I'm going to have to agree with the first two comments, you will need to reduce the paint to get it flowing well, you could buy some optional parts (needle, nozzle etc) to help you spray thicker (heavier paints) if you wanted.
The brush will work great once you've got it going for you though.
Here is a link to the parts guide for the HP C +
http://www.iwata-medea.com/images/iw...%20IM_REV2.pdf
You will see there that the C+ has two options for nozzles, small and SMALLER! .3mm (stock) and .2mm
Now, if what you have is an HP-C (not a Plus), you can convert it to .4mm. Still a small orifice for most of the paints used in RC painting, unless you reduce viscosity. And still too small for metallics, and forget about glitter or flakes.
The HPC+ is really a fine arts airbrush, intended for artists who spray thin media.
Read at Iwata's site and you will see the .5mm brushes are stated as best for thicker materials, and the Revolution CR is stated as intended for RC work.
I own an HPC and NEVER USE IT.
I own three HPCS's; the one that I setup for .5mm is used 98% of the time. The .35mm brush is used for chrome and Alclad or Spaz (water-thin paint).
For flake and glitter, I have a siphon Badger with a 1.0mm nozzle and pull the needle back out of the nozzle and blow it on like single action.
I wish people would stop wasting their money on high end brushes like HPC+ and Kustom HighLines and then complain that they won't shoot wallpaper paste (FasWhite).
Read up and ask questions before you buy, and you won't get stuck with a $300 brush that doesn't function for the work you intend to do.
You don't buy a Cadillac CTS to haul horse manure. Sure it's a nice car, but a Ford F150 is the right tool for the job.
Dave why didn't you throw your 2 cents in on my Iwata ? thread? I went and ordered the HP-C Plus. I should have went with the HP-CS huh??
The plus is a good brush, I'm sorry but an hpcs doesn't atomize as well as the plus, just thin your paints with 4011 reducer, get a shit brush for the metallics and opaques, you bought a good brush, besides, the hpcs has a .35, nearly the same as the plus with its .30 nozzle, neither brush is good for metallics...
I really don't think the HP CS has held me back in my painting. When I want finest atomization, I use better paint with finer pigment, or shoot straight transparents, which have no grain to them, just pure tint.
No question the HPC+ is a better and more costly tool, it's just not best for EVERY media. Iwata even says this in their literature. Different media perform differently in different tools.
In the end, each person decides which too is best for what they hope to accomplish with it. Too many people assume more expensive is better.
One of the best painters I've seen does most of his work with the RevoCR, and it is his skill in controlling the tool that makes his work outstanding.
Dave is pretty much giving the most accurate advice, and while I would love to help every one as much as possible, I think its best I just be quiet and point out that he is clearly going to be the best person to listen to in this regard!
Good stuff, I love how a thread, through questions and discovery lead to great information for those that arent able to find it on their own.
Dave, "you da man" ps, did you ever get that camera app lol?
Thanks to everyone for the info. I'm glad that I didn't put out the $200ish for the brush (not that my wife would let me lol) Sometimes "free" isn't all it's cracked up to be. I was wondering if there was a way to convert the HPCplus to a bigger needle? If not I'll just keep using my Neo and save my money to buy an airbrush with a .5mm needle
About what Dave said about the Revolution CR...That same artist led me into purchasing one when I first started. I use both the HP-CS and the CR and have to say I love them both...but the CR sure gives a lot of bang for the buck.
As far as a reducer...I use the 4011 and swear by it.
