Using Faskolor & Pactra on same body?
I was looking at colors I would like to use for an upcoming paint job. Some of the "ideal" colors are Pactra, while others are Faskolor. Pactra has a few greens that are perfect, while Faskolor has a perfect purple. So, the question is this: have any of you used both Pactra & Faskolor paints on different/adjacent parts of a body? One is lacquer and the other is water-based but both are intended for Lexan, but I wonder what would happen with overspray of one kind layering over top of the other on a previously-painted region.
I'd use both if I could, but I don't want to have one paint attacking the other or have areas peel or flake off due to bad adhesion.
I should mention I already have some Pactra that I bought in advance for this project, so I'll stick with Pactra if necessary, but I'd sure like to use some of those Faskolor colors.
Thank you for the help!
