Backing the paint (Faskolor) with others Spray can (not Pactra or Tamiya)
Just wonder, anybody ever use others spray can like Rust-oleum (White), ... backing the Faskolor paint. Does it work? What else we can use and
easy to get it in Home Depot, Wat-mart, ...
i use plastikote enamel clear to back/protect my shells and that is over createx etc so i don't see why you couldn't use the same paint but with their colors.
I use Rustoleum High Performance Black, White, or Clear on all of my bodies. It is the best stuff I have used to back bodies with. I have had zero problems using it with FasKolor.
I get it at Lowes, but you can probably get it at Home Depot too.
I have been using Rustoleum enamel krystal clear...EXCEPT to back when the project includes mirror chrome.
Even when there are several layers of createx/faskolor paint over the chrome it still seems to dull the chrome a bit for me...So I use a crapload of Faskolor Faskoat in those situations instead.
As far as using an enamel white to do the final coat AND for the final color...I never tried that yet. Anybody here use that with success?
As long as it's not Lacquer, you should be good. Lacquer can cause FasKolor to lift and crack. It has happened to me too. I don't have much experience with rattle can R/C paint, so I don't know. But I know it will not protect as good as the Rustoleum will.
I paint the whole body with FasKolor, then back the whole thing with a heavy coat of Rustoleum.
