spraying liquid mask...
#31
Can you spray on RCS liquid mask with a Badger 250? Needs some thinning down or not? If so, water would do?
#32
Just curious I seen there has been two mentioned HLVP guns to use from Harbor Freight. One is a 0.6 tip for $13.99 and the other is a 1.5 tip for $15.99.. I like how the 0.6 is a little smaller. I will be shooting just Bob Dively's if that makes a difference. Thanks!
#34
I ended up going with the 1.5mm tip and it sprayed awesome! The only issue is my small oil free compressor can't keep up with the volume the HVLP gun uses for air. I read a bunch but it sounds like I am better off with an oil free compressor. Thinking about going with this compressor. My compressor now is 1/3hp cheap one from harbor freight and just doesn't have the CFM I need. I use a filter on the line as well. Any suggestions would be great! Thanks
http://www.lowes.com/pd_470442-30449...uctId=50129758
#35
#36
http://www.harborfreight.com/20-oz-h...gun-47016.html
#37
picked up one of these today for liquid mask (comes with the 1.4 tip). they are on sale for $9.99 with the coupon code 56395719: http://www.harborfreight.com/20-oz-8...gun-67181.html
#38
I paid $13.50 for mine... It works well, but I wish I could find a smaller cup for it.
#42
#43
#44
I ended up upgrading to new compressor. I don't even know if a pancake one would be much better. I ended up purchasing the kobalt 1.8hp oil less compressor from lowes. It keeps up much better!
