spraying liquid mask...
#21
one of our LHS uses Elmer's Glue (white glue) as masking
http://www.elmers.com/product/detail...ome-and-office
it is cheap, dries fast and if coated properly (3 to 5 coats) is very effective in masking and easy to remove if you want to remove it already.
#27
Thanks so much. I Just got home from getting my gun..
Masking shall be easy!
#28
I've always used Spraylat Sign Strip II. Its about $25 a quart, $75 a gallon, and $263.86 shipped for 5 gallons (exactly that much on ebay). Its waterbased so just thin with water if needed, I never did though. I'm not sure how the other stuff holds up but I use this mostly with autobase and holds up just fine with the harsh reducers.
#29
Can you spray on RCS liquid mask with a Badger 250? Needs some thinning down or not? If so, water would do?
