Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Old 12-07-2010, 04:34 PM   #1
Jimmy Avila's Avatar
Trader Rating: 81 (100%+)
Default Removing unwanted overspray?????
I was painting a lexan body today and thought I masked the front of the car but when I pulled the masking tape that seperates the front/back I sprayed a little blue where I was gonna paint white. its just a little spray can I use paint thinner or nail polish remover or something to remove it? Btw I'm using water based paint.
Jimmy Avila is offline   Reply With Quote
Old 12-07-2010, 04:52 PM   #2
chris moore's Avatar
Trader Rating: 85 (99%+)
Some isopropyl alcohol on a q-tip works great, or a paper towel if the overspray is larger. Be carefull and take care to not dribble any on the part you allready painted.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-07-2010, 04:54 PM   #3
Trader Rating: 18 (100%+)
Default overspray
If you use a thinner of any type, chanes are you will leave a residue of the color you want to remove.
I use a Scotch Brite green pad. Works great, does not leave any color residue which will show through onto the white paint
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 12-07-2010, 05:03 PM   #4
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
If it is just ghost farts then you might be able to remove it by rubbing with a terrycloth rag, if it is drops then you could rub it off with a toothpick, another if there isnt too much try a cottonball and some rubbing alcohol. be sure it is very clean before spraying white there, the white will bring out everything!
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 12-07-2010, 11:31 PM   #5
Reedy26's Avatar
Guys, he said he is using water based paint. Just use water & paper towels. Ive done this with water based paint that had dried overnight.
*VV* J.R.S Custom Airbrushing Thread *VV*
http://www.rctech.net/forum/painting-designs-graphics-photography/458522-j-r-s-custom-r-c-airbrushing.html
Reedy26 is offline   Reply With Quote
Old 12-08-2010, 02:06 PM   #6
Trader Rating: 39 (100%+)
Denatured alcohol. Works quick and won't harm lexan. Use a cloth or microfiber towel to keep scratching at a minimum. Paper towels tend to scratch.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
SEO by vBSEO 3.5.0
