Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Old 05-20-2004, 12:18 PM   #16
andyobaez's Avatar
Send a message via MSN to andyobaez Send a message via Yahoo to andyobaez
Originally posted by rctoyguy
How do you not have a hard edge around the edge of the picture when you cut it out? I guess you just have to take lots of time to cut the picture to get the edges as clean as you can...
Your guest is right.
It's take a lot of time and patience. And because I don't want the background of the picture I needed to cleaned carefully, I used a X-Acto Knive to did it. Also I printed the photo in a photo paper and give a smoth surface when you paste the picture and to protect the edge I use the black.
On the civic body, I notice the area inside the girl's arm is black as well - was the picture of a girl against a black background...
The background was white, but didn't look good, and I wanted to give a shadow effect to the picture so was a better idea to have all back, also as I said before protect the edge of the picture.
I hope this answer your question.
Andy BŠez, Puerto Rico
http://www.facebook.com/pitlanehobby
andyobaez is offline   Reply With Quote
Old 05-22-2004, 04:54 PM   #17
Wency_TA03R-PRO's Avatar
Exclamation
Hgcolors
I like the concept on the engine image. its cool!! As well as the underside part of your rs4 pro2, that girl really looks good and almost a perfect fit on the underside..
Andyobaez
Its really a hot babe you got there dude!!. Did you mix a glitters on your blue paint?! man it great sparkling!
Keep it up guys!!! Hope I can see more cool pics on this thread.
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-07-2004, 05:15 AM   #18
andyobaez's Avatar
Originally posted by Wency_TA03R-PRO
Andyobaez
Thanks.
The blue paint is like that, came with the glitters.
Old 07-07-2004, 09:04 PM   #19
Exclamation
ah ok. tnx...
Old 07-08-2004, 01:39 PM   #20
What is it with putting chicks on your cars? Not that I'm gay but haven't you heard the rule? What you see on the computer stays on the computer?
Can I get by with some el-cheapo glue like a glu-stick? How d you use shoe-goo for picture pasting??
The Black Kat is offline   Reply With Quote
Old 07-09-2004, 06:37 AM   #21
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default shoe goo?
chick? what chick? i looooooooooove them!
ok... back to your question.
i think the main reason we use XXX MAIN glue or glue that have the same effect after drying, is, NOT TO SEE THE GLUE BETWEEN THE LEXAN and THE PICTURE. Means the GLUE will become CLEAR after it dries.
Further more THE XXX MAIN glue and the glue equivalent to it will have this elasticity and will expand and shrink accordingly.
If you are pasting picture under the chasis, no need to use the XXX MAIN glue because you wont see the glue at all behind the picture.
But i would not want to paste pictures under the chasis because definitely the picture will be scratched!!!!!
mop
mop_iko is offline   Reply With Quote
Old 07-10-2004, 12:33 PM   #22
Ford Sport Trax with a Cobra 427 motor......Elmers glue dries clear.
calvin3 is offline   Reply With Quote
Old 07-10-2004, 12:42 PM   #23
Switch Blade's Avatar
Send a message via AIM to Switch Blade
you can use internet photos with the xxx main glue right? I want to put marilyn manson on my r/c body, but cant seem to find any pictures of him in a magazine
College
Switch Blade is offline   Reply With Quote
Old 07-19-2004, 03:30 PM   #24
rctoyguy's Avatar
Trader Rating: 21 (100%+)
I assume paint sticks to the XXX-Main glue (or elmers) - I would think there would be some glue squish out from under the picture around the edges, then when you paint, you would be painting over the glue (glue between the paint and the lexan) - is this a problem? Do you have to clean away any glue that gets out from under the picture?
Jeff
rctoyguy is offline   Reply With Quote
Old 07-29-2004, 04:11 PM   #25
Exclamation
Try to apply the glue on the center of the image then gently press the picture from the center and slowly spread the glue under the picture by fingers/flaten the picture. calculate enough glue to apply so that excessive glue coming out from the edges will be minimized. Just a suggestion...
Old 08-05-2004, 01:00 PM   #26
Default Re: paste picture inside body??????????
Originally posted by bst
i have seen "how to" articles on gluing photos to the inside of a lexan body. has anyone ever tried this, and are there any pitfalls?
thanks, don
Use some lexan glue, but if any over runs, try to get it off asap. Then, just simply spray your design over the picture, just like a normal shell.
EVO4man is offline   Reply With Quote
Thermal paste between heatsink? Jonro Nitro Off-Road 10 09-20-2008 11:34 PM
DECALS INSIDE OF BODY? jhawk Painting, Designs, Graphics and Photography 11 01-22-2008 05:17 AM
How to protect inside of the body? nwilcox88 Painting, Designs, Graphics and Photography 0 03-30-2006 09:53 PM
FS: TC3 ++$140++ (picture inside) maximebeauvais R/C Items: For Sale/Trade 7 05-05-2005 01:23 PM
Decal for inside body AcadDude Painting, Designs, Graphics and Photography 12 09-24-2004 11:13 PM
