How to paint ghost flames
To make a ghosted flame you need to use a color very similar to your base or even the same color with a different backing color (e.g. if you used silver instead of white the ghosted flame would be the same color, but would have a metallic finish as apposed to the bright base color). The best ghost flames are versions that you can't se until you adjust the lighting... then they "pop". You can use light coats of various faschange paints to get the desired effect also.
If I were doing it, I would take the orange you plan on using for the body and add a few drops of silver to it when painting the flames. If you dont want to go the metallic route add red to make them dark ghost flames or yellow to make light ghost flames.
If you are using rattle cans you could tape out the flames and spray them with a very fast very light mist of silver. Untape the flames and paint the orange you wanted for your body.
Buy some sheet lexan to test your methods on!
ghost flames
I have a Kyosho USA-1 body and I want to paint it all white just the real truck is but I want to do some kind of ghost flame . How would it look to do the flames in pearl white and the rest of the truck in just white ? Or would something else look better on that white ? I would like it so it is just faintly visable until you change the angle you look at it . This body is very rare and I want to do it right the first time . Being hard to find, it is a bit expensive to do more than once . Any advice or input would be appreciated . Dave , any input ?
Hey Dave, Is that just a red on top of the orange, or a darker orange?
i have sold the car, so i cant show you a picture, but the method i used was to first paint the flames with a good coat of holographic paint by spaztik, followed by the chameleon paint (i used blue-purple-green-gold-red) over the whole body, and then backed by black. the flames, and skulls changed colors like the body, but were much more metalic in appearence than the rest of the body. depending on your lighting and angle, you either seen them or you didn't.
Hi Shoe,
use pearl gold, yellow or orange tinted with the orange that youre using to paint your base color, practice on whatever you use to do your draw downs on (two liter clear bottles cut in pieces, the cut offs of other bodies, etc..) until you get what youre looking for. But, pearls are the only way to go to achieve the true illussions of ghost flames youre looking for.
