Compressor Question
Compressor Question
I'm looking at buying an airbrush kit but have a question about the compressor. I currently have a porter cable pancake compressor. Would I be able to use this compressor? The psi can be adjusted from 15-150psi. Or would it be worth buying a compressor made specifically for airbrush? Any info is appreciated.
This is the compressor I have - http://www.cpoworkshop.com/combo_kits/cf6111.htm
Just about any compressor will work with an airbrush. You will want a decent filter-regulator that allows you fine control of air pressures between 5-40psi. That is where you will spend most of your time. Having a decent water separator is also a must with any paint sprayer setup, unless you live in a true high desert, lowest humidity area.
i wrote this up on another site,please read towards the end,thanks ,i hope it helps
http://www.beatyourtruck.com/forum/s...ad.php?t=63774
As far as the water separator goes I put couplings on mine so I just pop it on the compressor then plug the hose into it for airbrush,trim gun etc.
If you have an outgoing pressure gage (not tank pressure) you can dial it in with the stock regulator.
