mount hole tips
mount hole tips
Got my desert rat body ready to be put on. Was wondering if anyone has tips on how to cut the mount holes or if the indents on the body are correct for the post...thanks
If the body you bought was specifically for your car, then yes the dimples will line up.
If the body is not for your specific car, first cut the body out if you haven't done so already. next grab some mustard, yes the yellow condiment!! put a SMALL dab on top of each body mount.
CAREFULLY lower your body onto the car, make sure it is square and lined up good. touch the body to the mustard and voila! Now you know where to put your holes!
Just use a body reamer to make the holes.
