faskolor PSI
Old 10-24-2009, 07:04 AM
revo61's Avatar
Trader Rating: 18 (95%+)
Default faskolor PSI
What PSI do you spray faskolor at? I have a Iwata HP-CR Revolution Airbrush, and spray at 50psi. On Parma's website they say 40-70 with a medium tip. What is considered medium?
revo61 is offline
Old 10-24-2009, 07:09 AM
Super Moderator
charlie_b's Avatar
Iwata only uses 1 tip...try 60 and go from there.
charlie_b is offline
Old 10-25-2009, 06:16 AM
revo61's Avatar
It comes with a .50 needle, but I can get a smaller .35 for it.
revo61 is offline
Old 10-25-2009, 06:31 AM
NeoNot's Avatar
I believe Charlie was saying you only have one needle and nozzle combo out of the box. As you stated this is the .5mm set. With that in mind try using 60 psi to start out with. If everything sprays fine lower the pressure until it wont spray then come back up until it works again.
NeoNot is offline
Old 10-25-2009, 09:50 AM
paco62's Avatar
+1
Always try on another material until you're comfortable with results.
paco62 is offline
