Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Old 08-25-2008, 09:25 AM   #1
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Default Window Trim mask easy in Adobe Illusterator.
If some of you have wondered how to design a window trim on the computer, here is one easy way to do it using Adobe Illustrator.
For more tips and tutorials, go to www.cfxpaintworks.com
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
CFX Paintworks:www.cfxpaintworks.com
OC Circuit:www.facebook.com/occircuit OCCIRCUIT PAGE
|HITEC|PARMA|SPEEDPASSION|SWEEP|SPAZSTIX|IWATA|RPM |THUNDERPOWER RC|PTI
charlie_b is offline   Reply With Quote
Old 08-25-2008, 09:49 AM   #2
RCSteve93's Avatar
Thats awesome. Good tutorial. I prefer my X-Acto though.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 08-25-2008, 05:04 PM   #3
MikeXray's Avatar
Trader Rating: 59 (100%+)
Any tricks to making something that comes to a point not have a flat end? If you goto 4pt stroke, it flattens the point, I can manually fix it, just cuirous if there was a different way, the 3 cap choices don't do it. (Illustrator 10).
Mike L. <> www.MikeLdesigns.com
RB6 / AE B4.1WC / Kyosho SCR / SC10 4x4 // TQ Wire- tqracing.com | Sweep Racing |JacksonRCracing.com | Horsham RC | sidepieceracing.com | islandraceway.com
MikeXray is offline   Reply With Quote
Old 08-25-2008, 06:53 PM   #4
Super Moderator
charlie_b's Avatar
What you can do is with the pentool, hit alt and slightly curve your line then connect the rest. Once you close your path, it should be sharp at the end.
Old 08-26-2008, 09:15 AM   #5
RC Dad's Avatar
Trader Rating: 25 (100%+)
Send a message via MSN to RC Dad
I've done designs in Photoshop, but what type of material do you print them on?
I tried full-sheet avery labels, which are expensive paper and don't always peel nicely after being cut out - they always seem to have rough edges. I'm way more accurate with a scissor than an xacto, which may explain the rough edges.
Also, this works great for decals with complex graphics but the label paper doesn't hold up well to wear and washing onthe outside of the body. Is there a clear material available to ink-jet the designs onto?
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 08-26-2008, 09:26 AM   #6
Super Moderator
charlie_b's Avatar
Yes, they clear vinyl you can print on from Avery. I highly do NOT recommend Avery labels though. Because it is paper based, the paint with eat into them and make your paint bleed.
Old 08-29-2008, 07:55 PM   #7
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Mike, just change the "miter joint" setting to a higher value like 200. Miter joint is just below the stroke weight setting.
Although for window trims, I usually prefer a rounded joint even if I have to use a tight radius.
BigDogRacing is offline   Reply With Quote
Sponsored Links
Window Trim? Tire Chunker Painting, Designs, Graphics and Photography 1 03-26-2008 05:41 PM
Window Mask -- Sticky goo left over DOMOisCOOL Painting, Designs, Graphics and Photography 12 05-30-2006 08:19 PM
Window Trim HiImATreeHugger Painting, Designs, Graphics and Photography 3 05-11-2006 03:28 PM
Liquid Mask & Window Masks... rctoyguy Painting, Designs, Graphics and Photography 9 03-13-2006 08:05 PM
Window Trim Painting scoobydo Painting, Designs, Graphics and Photography 25 02-21-2005 05:40 PM
SEO by vBSEO 3.5.0
