Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Like Tree110Likes
Old 09-02-2014, 01:42 PM   #5026
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by nf_ekt View Post
I like it. Only thing I would do differently is hold off on the decals on the sides (the flames are nice so that is what I want to see the most of). Good work.
Jon, in this particular case and unless I'm mistaken, I believe these truly are his sponsors.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 09-02-2014, 02:46 PM   #5027
NutDriver's Avatar
Trader Rating: 14 (100%+)
Let me put it out there again...
What rattle can color best approximates the blue on the BFG TireBird?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-02-2014, 08:46 PM   #5028
snoopyrc's Avatar
Testors custom lacquer system has a GTS blue that might get pretty close.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 09-03-2014, 12:31 PM   #5029
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Regular Tamiya Blue if backed with silver/white may work. Otherwise Tamiya Brilliant Blue backed with black or purple. Brilliant Blue is brighter, regular blue is darker!
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 09-03-2014, 01:43 PM   #5030
NutDriver's Avatar
I have painted a body with Tamiya blue backed with silver and it's pretty dark. I'll find some scrap and try Pactra Brilliant Blue backed with a couple of different colors. Thanks for the info.
USVTA member #111
Old 09-04-2014, 12:43 AM   #5031
Thumbs up
Pactra (light coat of) candy blue,then Pactra brilliant blue, backed with Pactra white, silver if you want it brighter.....Should be pretty close.... Try it on some lexan scrap.
THEBIGBULL is offline   Reply With Quote
Old 09-04-2014, 09:14 AM   #5032
DBM
I don't think that I ever did get around to posting a pic of my vta car. Simple single color paint scheme (with the exception of the chin spoiler). Mixed Faskolor pearl black with Faskolor silver to get charcoal.
I originally painted it with a 4-color scheme, but I didn't like how busy it looked (it took Ady from the awesome style of the Camaro), so I washed off the paint with boiling water and a toothbrush. :P
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-20140523_141047%7E01.jpg
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 09-04-2014, 07:38 PM   #5033
DBM
I bought a j71 body yesterday, and cut it out tonight. After comparing it to the hpi camaro, the camaro doesn't seem as disadvantaged as I had assumed. The nose on both is the same height, and the rear spoiler on both is the same height. The j71 is indeed lighter, but I have not painted it yet, so won't bother reporting their weights until I paint the j71.
Old 09-05-2014, 03:07 AM   #5034
theproffesor's Avatar
Trader Rating: 55 (100%+)
It gets alot heavier once you add the shoe goo to the front to hold the nose on.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-05-2014, 09:41 AM   #5035
DBM
How difficult is it to remove the nose once it is shoe goo'd on?
Old 09-05-2014, 09:42 AM   #5036
Tommy R's Avatar
Trader Rating: 19 (100%+)
Not sure it's possible without destroying the body and/or paint.
Tommy R is offline   Reply With Quote
Old 09-05-2014, 09:46 AM   #5037
Depends. If you did just a single bead of goo and then used the screws, you should be able to get the nose off without damaging the lexan lip. That lip will be ugly but will be covered up once you put your SECOND nose on.
Re-using the first nose may not be possible.
You did paint the second nose didn't you...?
.crispy is offline   Reply With Quote
Old 09-05-2014, 09:53 AM   #5038
It tears up the lip on the body pretty good, but there is enough left on to glue the second nose too. IDK why you would want to re-use the first? Also on second nose, put some drywall tape and shoegoo over the seam and it holds really well
Old 09-05-2014, 01:35 PM   #5039
NutDriver's Avatar
I'm not a fan of using drywall tape as it is not structural. I recommend buying the wing-joining fiberglass from the airplane section of the hobby shop.
USVTA member #111
Old 09-05-2014, 04:13 PM   #5040
beemerfan's Avatar
Trader Rating: 34 (100%+)
I used fiberglass drywall tape and epoxy to repair my RS4-MT chassis and its at least as strong as the original. In the photo I've used two layers of it with 30 minute epoxy. I've also done several airplane wings with it and never had a failure. All the bodies I've repaired with it using Shoe Goo have held up very well.
USVTA Member #155
Associated TC3 Faithful
beemerfan is offline   Reply With Quote
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 09:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 07:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 03:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 03:09 AM
