Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Like Tree108Likes
Old 12-26-2012, 10:51 AM   #3496
IndyRC_Racer's Avatar
I hope everyone is having a happy holiday season.
I hope everyone keeps posting ALL of the pictures of their late 60's thru early 70's pony cars.
Not every body will be fully USVTA legal, but that is okay. I am going to just appreciate the effort that went into the paint scheme. Maybe it will inspire me to get off my rear end and paint the 2 bodies I've had sitting around for months!
So...keep those photos coming!!!
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 12-28-2012, 01:54 AM   #3497
Default HPI '69 Camaro
Edit: I've found the answer, please ignore.
Hi there all,
I am looking at getting an HPI '69 Camaro shell which is 200mm, I've read on the HPI site that I can use a 190mm TC if I use the higher offset wheels, which is fine, I can see you can get fronts in 0,3 and 6mm offset, but the 31mm rears only appear to have one offset so i dont think they will fill the arches enough.
I've looked through this thread and there are alot of Camaros on here, so surely it must be possible?
Cheers
Team Losi XXX-CR | XXXT-CR | JRXS-R | JRXS | XX-CR | XXT | XXT-CR G+ | Mini-8ight | TLR22 | TLR 22T
J A M I N is offline   Reply With Quote
Old 12-28-2012, 02:34 AM   #3498
Sith Lord's Avatar
Trader Rating: 21 (100%+)
6mm Offset with the 31 rears is all you need, and all everyone uses. Below is my 69 Camaro on a 190mm Xray Chassis. Fills out nicely, I reckon!
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is online now   Reply With Quote
Old 12-28-2012, 06:05 AM   #3499
The Captain's Avatar
Does anyone have some pictures of headlights on a HPI 1969 Camaro Z28? I have some on mine, but they dont look very scale.
I'm trying to figure out a way to make them more scale looking on my next body. What I was planning on doing for the tail lights was using surface mount square LEDs in parallel to take up the entire tail light recessed area, and shoe gluing them in place behind the lexan. I was thinking of doing the same thing with the headlights, as they make circular surface mount LEDs. Just find one that will take up most of the head light area and glue in place.
Suggestions, ideas, pics?
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-28-2012, 06:39 AM   #3500
Marv's Avatar
Questions??
What maker and shade of green is that?
And what color did you back it with?
Originally Posted by The Captain View Post
Marv is offline   Reply With Quote
Old 12-28-2012, 07:16 AM   #3501
That is Pactra Metallic green (rc266) backed with Pactra outlaw black (rc250). It was a little lighter than I wanted, thats why I backed it with black. Turned out AWESOME!
Before backing
-Derrick-
Old 12-28-2012, 08:41 AM   #3502
Did you use a light bucket with your headlights? The bucket should help diffuse the light and might better fill the space better.
You can also try painting the tip of the bulb to help eliminate the hot spot in the center.
Old 12-28-2012, 08:53 AM   #3503
Marv's Avatar
Thanks Captain! Looks awesome!!!
That's exactly what I did on the HPI 70 Boss shell I have.
Then I backed the white with black so the shell wouldn't retain heat.
I slipped trimming it and wound up circumcisizing the front spoiler.
Sorry about the pic =
Its snowing outside and my inside lighting doesn't do the paint justice.
Better ones at another time.
Before backing
Holy crap!
I shop at Walmart too!
AND I use the same brand of Sea Salt!!!
But I don't have kissy face doggie salt & pepper shakers...
Old 12-28-2012, 08:55 AM   #3504
Yeah, I used some of these I had laying around from another project:
Marv, at least the dogs are "scale" lol!
-Derrick-
Old 12-28-2012, 09:49 AM   #3505
SS LS1's Avatar
Trader Rating: 23 (100%+)
I made reflector buckets from some flashlight bulbs from Lowe's and mounted them behind the body.
This way the light shines through a lens looking more like a HID projector retrofit.
Not exactly scale in diameter but it does look nice overall.
Nothing fancy for the rear as the body was already painted.
Future projects I would mask the taillight area and shine leds through the body and the taillight decals like I did on my BMW USGT body.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20120121_110251-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20120121_110320-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20120121_110356-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-2012-12-05_17-17-34_367-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-2012-12-05_17-18-27_63-medium-.jpg
SS LS1 is offline   Reply With Quote
Old 12-28-2012, 09:53 AM   #3506
SS LS1's Avatar
Did the same reflector buckets and mounted them behind the body.
The diameter is scale on the Dodge Challenger body and even looks good when the lights are off.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20111202_171523-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20111202_171848-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20111202_171832-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20111202_171910-medium-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_20111202_171720-medium-.jpg
Old 12-28-2012, 10:21 AM   #3507
SS LS1, my tail lights on the Camaro look exactly the same, black clips and all
These are the type of LEDs I'll be using on my next body for the tail lights
And probably something similar to this for the head lights
I've got to get the calipers out and take some measurements, then order some parts to do some testing. I'll wire them up using black magnet wire for a nice clean install. I'll be sure to post pics of the process.
-Derrick-
Old 12-28-2012, 01:15 PM   #3508
rdx4vta's Avatar
Can anyone point me to a purple challenger that may have been posted? No good way to search for a picture, and 234 pages of posts is quite a bit to sift through...an username to search for would be great. Much appreciated!
Corally RDX 25.5 USVTA
rdx4vta is offline   Reply With Quote
Old 12-28-2012, 03:09 PM   #3509
Great looking Vta !
bertrandsv87 is offline   Reply With Quote
Old 12-28-2012, 06:12 PM   #3510
Potoczak's Avatar
Trader Rating: 109 (100%+)
How do you guys get the white letters on the tires to stay on?? Is it paint or stickers??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 09:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 07:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 03:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 03:09 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
