What brand Paint?????
Alright most of my R/C time ive used rattle cans all one color of the Pactra persuasion. But last time i used it the paint was flaking off during my race. Now ive got an airbrush kit and want to try and do more artistic things my q's are what brand should i use (Pactra has left a bad taste in my mouth), how do you thin the paint.
Then your obviously spraying it in the wrong place.
anyhow, pactra flakes off if the body isn't cleaned properly, and it's not thinned enough. I do about 50% paint, 50% lacquer thinner. I also use spazstix paint for some cool candy colors, that stuff doesn't need to be thinned.
Parma paint seems to be the most popular due to the lesser smell of WB paints. Pactra & other lacquer paints will yield a smoother pattern and are easier to use for most. The key to making any kind of paint work well is proper reduction coupled light even coats.
I use an AB with a .38mm needle have have found the following mixes to work well as a starting point.
Pactra solids: 50% paint, 50% reducer @ 15psi for detail, 20psi for coverage
Pactra candys & pearls: 70% paint 30% reducer @ 15psi
Kustom Kolors: 70% paint 30% reducer @ 10-15psi. base coats & 20psi.
Faskolor I think with a 50/50 mix of water & alchol with 1 drop glycern per 2oz.
Solids for coverage 75/25 paint to reducer @ 25-30psi.
Solids for detail 50/50 @ 20psi. Use semi-transparent paints for better transitions whenever possible.
flourescents 60/40 @ 15psi for detail or 75/25 @ 25psi for coverage
candys, pearls, fascents, & faslucents 75/25 @ 15psi for detail or 25psi for coverage.
Mark
Mark
