Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-10-2007, 01:43 PM   #1
paul73rc's Avatar
Trader Rating: 5 (78%+)
Questions?? HELP - AIR BRUSH - HELP WHEN AIRBRUSHING WHAT PAINT DO I USE? POLYCARBONATE? HELP!
HI GUYS, I AM ABOUT TO PURCHASE ABOUT 40 RC CAR SHELLS TO PRACTICE AIR BRUSHING ON THEM. I HAVE A MATE THAT SELLS THEM FOR $5 A SHELL THAT'S WHY I AM GETTING 40 LOL. NOW I AM GOING TO PURCHASE AN AIR BRUSH KIT AND SOME PAINT BUT I DON'T KNOW WHAT AIRBRUSH KIT TO GET AND WHAT PAINT TO USE FOR LEXAN SHELLS???
WHEN I SPRAY PAINT LEXAN SHELLS I USE THE NORMAL TAMIYA POLYCARBONATE CANS OR THE LRP POLYCARBONATE CANS ETC. BUT WHEN I THOUGHT OF DOING SOME AIRBRUSHING I WASN'T SURE IF I CONNECT THE CAN TO THE AIRBRUSH OR WHAT?
SO COULD THE MORE EXPERIENCED AIR BRUSHERS PLEASE TELL ME WHAT IS A GOOD AIR BRUSH KIT TO START WITH AND WHAT PAINT DO I USE?
CHEERS, PAUL
paul73rc
paul73rc is offline   Reply With Quote
Old 12-10-2007, 01:51 PM   #2
bvoltz's Avatar
On the airbursh side, someone eles will need to touch on that topic..
Paints:
http://www.testors.com/catalog_brand...br=5&ictNbr=49
or water base:
http://www.parmapse.com/Images/FASwatches.jpg
bvoltz is offline   Reply With Quote
Old 12-10-2007, 01:59 PM   #3
paul73rc's Avatar
Paints:
or water base:
THANKS ALOT FOR THAT BVOLTZ. MY LOCAL HOBBY SHOP SELLS THE WATER BASED PARMA PAINTS. I DIDN'T EVEN KNOW WATER BASED PAINT STICKED TO LEXAN SHELLS. SWEET! THANKYOU SO MUCH BVOLTZ!!! ONCE I KNOW A GOOD AIRBRUSH KIT I WILL GO OUT AND BUY SOME PAINTS! CHEERS, THANKS AGAIN
paul73rc
Old 12-10-2007, 02:04 PM   #4
paul73rc's Avatar
HI GUYS, ONE MORE QUESTION. IF I WERE TO USE THE PARMA WATER BASED PAINTS AND DURING THE PROCESS I STUFF UP CAN I QUICKLY WASH THE PAINT OFF WITH WARM SOAPY WATER OR SOMETHING?
paul73rc
Old 12-10-2007, 03:05 PM   #5
Trader Rating: 42 (100%+)
Send a message via AIM to weaponx
For an airbrush I would reccomend an Iwata Eclipe BCS. If using Faskolor, windex is what I would suggest for thinning the paint, and get a good compresor. I reccomend buying decent stuff from the get go, it will making the learning curve much easier, then if you try to save a couple dollars.
weaponx is offline   Reply With Quote
Old 12-10-2007, 03:29 PM   #6
paul73rc's Avatar
How much is a Eclipse BCS? Also how much windex do I use to thin it out? Is there a ratio anywhere, such as 10 ml and 3 ml etc? Also I already have an air compressor but what psi should I do the airbrushing at? Thanks again weaponx, all help is appreciated
paul73rc
Old 12-10-2007, 04:31 PM   #7
bvoltz's Avatar
http://search.ebay.com/iwata-eclipse...20EclipeQ20BCS
This will give you an idea...
Old 12-10-2007, 04:42 PM   #8
Unfortuneatly with faskolor, its hard to give a ratio for thinnig, as the faskolor itself varies, depending on if its a flourescent color or an opaque color etc etc. Its more of a learn on the go. I usually spray faskolor between 25 to 40 psi, again this kind of depends on the consitency of the paint.
Old 12-10-2007, 04:52 PM   #9
Parma Faskolor is a great waterbased paint...
Definitely go for a Iwata airbrush though, they are top of the line and worth the money...
tanman44 is offline   Reply With Quote
Old 12-10-2007, 05:37 PM   #10
paul73rc's Avatar
Hi guys, Thankyou for steering me in the right direction. Now, I was just wondering is the Iwata Eclipse HP.CS a good air brush to start off with? If so is this a good deal?
http://cgi.ebay.com.au/IWATA-ECLIPSE...QQcmdZViewItem
Just one last question. If I spray a body with the Parma Faskolor waterbased paints and on my first body I stuff up bigtime which it wouldn't surprise me as it would be my first time. Can I wash it off straight away with water or something without wrecking the body?
Thanks again guys for all your wonderful help.
paul73rc
Old 12-10-2007, 09:14 PM   #11
Send a message via Skype™ to sliver-surfer
Thin fascolour until its the consistency of table cream. For Faskolors I use water if I'm just spraying coats/backing up and "Fantastic cleaner" when I do shading/blending/details. Use a hairdryer between coats. Another tip is get some small marbles to put in the bottom of your paint bottles for better mixing.
HERES SOME OF MY PAINT JOBS
sliver-surfer is offline   Reply With Quote
Old 12-12-2007, 12:10 AM   #12
paul73rc's Avatar
Disregard my questions about the paint from a hardware store. Didn't realise how cheap Parma Paints are. Not to mention I would be cutting corners if I went for a cheap paint.
paul73rc
Last edited by paul73rc; 12-13-2007 at 11:44 PM. Reason: Parma Colours Cheaper That What I Thought
Old 12-16-2007, 10:53 PM   #13
paul73rc's Avatar
Has anyone used Tamiya acrylic paints? If so does it stick good to the lexan?
paul73rc
Old 12-18-2007, 12:33 AM   #14
paul73rc's Avatar
Paints:
or water base:
Hey bvoltz just wondering do you know if it is possible to airbrush lexan rc bodies with the Tamiya acrylic paints? If so does it stick good to the lexan?
paul73rc
Forum Jump
Paint Monster Airbrushing. Mark T. Painting, Designs, Graphics and Photography 212 Yesterday 03:21 PM
Iwata Air brush with compressor & 18 bottles of paint Maxxborg R/C Items: For Sale/Trade 0 03-31-2008 10:39 AM
Complete Airbrush Setup....Paint, Compressor, Brush....take a look!!!! DotyThe8ight R/C Items: For Sale/Trade 16 01-26-2007 06:18 PM
Anyone paint Static Models (Tamiaya etc..)? Hiding Brush Strokes MikeWz Chat Lounge 38 04-28-2005 10:33 PM
Polycarbonate paint genexis Singapore R/C Racers 5 09-29-2003 07:56 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
