Mixing Faskolor paint
Hi
Can anyone tell me what is best to thin this pain with? I have read the Window lean is good but I don’t know what the UK equivalent is!!!
Tony
Tony
I have found that window cleaner works, but I stopped thinning it lately, it seems to adhear a little worse. Just make sure you spray the correct psi, and knowing fascolor paints I would guess white is your problem, and there isnt much I can seem to do to make the white stick better.
Hope that helps!
Hope that helps!
hi mate,
windex is an american window cleaner and windolene is the uk version.
i get mine from morrisons
make roughly a 50/50 mix of wndolene n water and thin ur paint with that
