outlined flames
why not?
just cut out the lines if you want to paint the lines first (ie deeper colors) or cut everything else except the lines if you want to paint the lines later (ie lightler colors)
what i use is pin-striping masking tape.. its very thin for detailing. works well and goes around corners easy. that way to don't have to worry about cuttin a straight line. Do that then peel off the Flame mask and paint that then peel off the outline and paint that.
yes you are correct
post pics when your done
