Iwata Compressors...
Power Jet - 70 psi maximum, 400 bucks.
Smart Jet - 35 psi maximum, 200 bucks.
Considering these two. Was wondering if 35 psi is enough for RC body painting?
edit - I already ordered the Iwata HP-CS, if that makes any difference.
PSI
Honestly, I never go higher than 20-30PSI, so that should be more than enough, unless you are planning to use a heavy duty sprayer for the liquid mask etc... then you need a much bigger compressor. I would definately pick one of the Iwata compressors up as they are very quite and efficient. Currently I used a heavu duty, automotive style compressor (8gal dolly) and its loud, really loud.. LOL Hope this helps!
Clint
Clint
