Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-11-2007, 10:52 AM   #1
Send a message via MSN to Apexs
Default Help request, polycarbonate body
Hi I need some help please, just painted my first polycarbonate body and of course I have messed it up, I did not realise iridescent pink/gold was like a lacquer and needed to be backed with black (clearly says paint black over top on the lid ), so of course I put to much on, which caused my paint masks to crinkle up a bit and let paint get under it.
1) What would be the best method for me to carefully clean and remove any paint from my masked areas? Without effecting the rest of the paint.
2) Or if I need to start again, what to use to totally strip the body so I can start again
Many thanks
Apexs is offline   Reply With Quote
Old 01-11-2007, 01:22 PM   #2
tcfree's Avatar
removing old paint or bad paint from a body?
STE.
tcfree is offline   Reply With Quote
Old 01-11-2007, 01:36 PM   #3
break fluid? the body is not as bad as i thought it would be after all, so all i need to do is clean some paint away from where its bleed under the masking, some of the detail i need to clean is very small
Old 01-11-2007, 02:24 PM   #4
scoobydo's Avatar
Take acetone or brake fluid and dip a Q-Tip in it.
Then start working the area that is covered.
Make sure you squeeze as much fluid out of the Q-Tip before applying as you don't want drops to leak onto the paint.
If it is an area that is going to be painted, first try to get as much off with the Q-Tip and then take some 500 grit (or higher) sand paper and lightly scrape away the rest.
When you re-paint, you will not be able to see the scuffs unless your using chrome.
As for the windows, your best bet is just the Q-Tip.
scoobydo is offline   Reply With Quote
Old 01-11-2007, 02:42 PM   #5
thanks
Old 01-12-2007, 02:24 PM   #6
HotrodHopkins's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to HotrodHopkins
depending on how thin the paint bleed is, you might be able to get if off with foam tyre traction compound.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1997 Dodge Ram 2500 Cummins 12v ECLB 4x4 5spd; 1990 Chevrolet K1500 Silverado TBI350.
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Forum Jump
HELP - AIR BRUSH - HELP WHEN AIRBRUSHING WHAT PAINT DO I USE? POLYCARBONATE? HELP! paul73rc Painting, Designs, Graphics and Photography 13 12-18-2007 12:33 AM
Teamwave Lightning top plate (Polycarbonate) GymBeam Australia For Sale/Trade 3 06-02-2007 06:28 AM
Tanya Cat buat body Polycarbonate akuhon Indonesia Racing 20 02-26-2006 09:17 PM
Polycarbonate paint genexis Singapore R/C Racers 5 09-29-2003 07:56 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
