Your Custom Paintjobs
I finished a few more bodies recently. I've been practicing alot and I'm slowly getting the drop shadows, but it's tough. It sure make you realize how good some of these guys are on this site.
[QUOTE=IndyHobbies.com;11768849]I use Faskolor paints almost exclusively. Seems like every once and a while, get a bottle that just fish eyes immediately. Its like they have oil mixed in the paint or something. Its not my equipment, because I'm often using several colors at the same time, and I've got a in-line oil/moisture trap.
The blue you see in this photo was from a fresh new bottle.
The solution is to mist it really lightly a couple of coats then apply a more even coat, but its still annoying. Anyone have this problem too?[/
Fast color is nice paint,I would be surprised if it has oil in the paint.and it looks like a lot of oil.I use water base creates a lot and any oil really trashes things. Did you try a new air hose ? And then clean the airbrush with dish soap.
This is a Short Course Truck body that I airbrushed last weekend for a local racer. I don't think I've ever spent more time working on airbrush job than this one! All the flames are edged with chrome which took a while. He says he's going to keep it for his Show body, rather than race it. I'm glad to hear that!
This is the TLR Losi SCT Hi-Performance lexan body that comes laser cut. Really nice quality and its got flow-through holes in the back to help the truck track straight on jumps. If you've ever hand cut those holes or dremeled them, you know what a BITA they are! The laser cut version is wonderful for that reason. Neon Faskolor paints along with fasescent blue and chrome.
I wish a Parme rep would be a part of this forum like the Novak guys do on the speed control forums. I can send Parma my question but then others don't get the benefit of an answer.
I wondered the same thing. I put a drop or two in the air compressor every few hours of running as they suggest, but I've got an oil/water in-line filter before my airbrush to (presumably) remove any that gets that far. And, like I say, I can switch to another color using the exact same equipment, a not have that problem. Sounds like others have experienced the same. I guess when I get a bottle like that, I could pitch it or try to return it, but that hurts the old profit margin, so I just get by with it doing really light coats and drying in between. Once a base coat is down, the problem is minimized.
two new ones for local guys
Don't you hate the roof lines on that pink one? They're a pain in the butt and get in the way...lol
Ya, the ribs in the roof makes it difficult to cut and it limits the amount if detail that can be added to the roof.
Are any of you guys that have the fisheye problems scuffing the body with scotchbrite or something similar before you paint?
Reason I ask is because we were having a fisheye problem with some 3 stage colors at our body shop. Found out it was because the layer he was spraying second was too smooth and he had to scuff between layers to get it to stick.
Could just be another option if you are weight conscious and not wanting to add the other layer of clear
Sparklesecent Mango. It looks incredible in real life better than a photo can produce. The rest is Spaztix.
http://www.autoaircolors.com/paints/4580.html
Tryed a rolling flag for the first time on this shell just have to get the shadowing a bit better and ill be happy with it, Any tips on the rolling flag affect.
Cant remember if i popped up my last XB9 shell so here it is...
My Bodies painted by FAZE...
Same theme we just tried switching up the colors this time.
All associated vehicles, Mod B4.1, Stock B4.1, Mod T4.1, Mod SC10
Yer if people are having problems with autoair it isn't the paint. It's either airbrush and pressure or they are using 4011 reducer when you should be using transparent base to reduce. The range is brilliant except for some of the fluro colours, but they may be because they were old from the supplier, once i filtered the paint it was perfect. I've even started painting my mancave walls and its all auto air, the best painters in the world use it so it can't be all that bad.
