REAL carbon fiber
REAL carbon fiber
ok...i have a honda s2k body. i want to make the hood/trunk and roof carbon fiber...instead of painting fake carbon fiber on it...is it possible to somehow glue actual carbon fiber material to inside of the body? any one seen this done(if so post pics). i have a sheet of carbon kevlar laying around and i thought it would work...just dont know how to get it to stick so u could see it clearly and perfectly. any input or suggestions would be appreciated..i plan on painting it yellow and just want to make it look as real as possible.
the fabric is easy to come by.just figuring out how t make it work is the hard part.
The first problem with using real carbon fiber is that you have to use it like fiberglass it has to be laid with a resin the raw cloth is not very cool looking like the finished product is. You need special resin for carbon fiber works basically the same but it cures clear not yellowish like fiberglass next in the curing process the resin will get bubbles in it you will need to get out with a matt roller that will not get them all out you will have to use a chemical spray to get the rest out but since your finished side will be under lexan it will be hard to get them out. The other problem is that the lexan is smooth it will act like a mold if it doesn't fall out immediately the first blow the body takes it will most like release. Not trying to discourage you it is probably possible to accomplish but not very practical.
I'm sure you can buy carbon fibre stickers.
http://www.xxxmain.com/sticker-galle...ber-8-11.shtml
Its not real carbon fibre but looks better than the painted stuff IMO.
i dont like the way fake carbonfiber looks..theres no substitute for the real thing
I've heard women say the same thing..
but they were talking about Gucci bags! (what did YOU think I was talking about?)
how could i get it to stick inside the body?
Originally Posted by dodgeguy
I sell Carbon fibre sheets of vinyl for $5. They are 8x11. It looks like real CF.Check out the pics.
Suspended
ohhh trust me they already got about 50 manufacturers with carbon fiber psp covers...
http://www.decalgirl.com/browse.cfm/4,2741.htm
decal girl is the largest because they have billions for everything, check out JUST the carbon fiber skins:
http://www.decalgirl.com/search.htm?...m=carbon+fiber
check every page^^^
check every page^^^
