Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Old 09-13-2017, 07:06 PM   #1
Default KSRC002 will not move
No internal transmission problems the gear drive axle turns when the body is pushed forward by hand I have checked the key and set screws pertaining to the gears can't find any reason it shouldn't be working can anybody help ?
Me002 is offline   Reply With Quote
Old 09-14-2017, 12:11 AM   #2
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Have you taken the side gear cover off, check the clutch on the engine.
roadrashracing is offline   Reply With Quote
Old 09-20-2017, 03:49 PM   #3
Yes I have there is nothing wrong with the clutch first gear should not spend freely on the drive gear axle
