Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Old 11-04-2014, 06:44 AM   #46
blackshark3's Avatar
Thanks for the tips guys, really helpful
blackshark3 is offline   Reply With Quote
Old 11-04-2014, 06:51 AM   #47
M7H
M7H's Avatar
no probs!
just be sure you use good plugs on 4S, because I also managed to melt the outside case near the connection of my lipo's when I geared my car to high...
Serpent
M7H is offline   Reply With Quote
Old 11-04-2014, 07:26 AM   #48
Originally Posted by M7H View Post
no probs!
Thanks for the heads up! So better switch to 5mm plug?
Old 11-04-2014, 09:50 AM   #49
BIBOY's Avatar
Send a message via Yahoo to BIBOY
A 2650kv motor on 4s, is just as fast as a 2000kv motor on 6s, so if you are looking for a set which you can use on 4s but also on 6s, go for a 2000kv motor max!, and gear up that pinion on 4s, until you reach the speed you want!
i did test my 966e with 4S lipo => https://www.youtube.com/watch?v=uwOzil59Mvg
check the description for set-up details.
To give you an answer on what pinion you should start with.
Lets take a 1800kv speed passion blaze motor.
If you want to gear the car to reach 85kmh, this is how you need to gear it.
1800kv x 3.7V x 4S = 26.640 rpm (theoretically)
check gearchart.com an fill in the figures you know and to find out the gearing you need to accomplish this.
- internal ratio = 1.714 (28/18)
- rpm = 26.640
- tire diameter = 73mm
And start playing with the spur (48 / 49 / 50) and pinion (14 => 21), until you have the desired speed, then check what roll-out goes with this speed.
If you fill in everything correctly, you will come to a roll-out of around 53,5mm and a spur / pinion of 50 / 20.
The "roll-out" chart you can also download from serpents website on the 977e page.
If I'm correct, a 21 pinion is the max pinion that fits the car.
thanks i for the info this helps a lot.. Im going 4s for sure it will just right for our track
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
BIBOY is offline   Reply With Quote
Old 11-04-2014, 10:00 AM   #50
BIBOY's Avatar
follow up question what is your tire split (front and rear diameter difference) thanks
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
Old 11-04-2014, 11:06 AM   #51
M7H
M7H's Avatar
7mm
Serpent
Old 11-04-2014, 12:12 PM   #52
BIBOY's Avatar
7mm
thank you so much
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
Old 11-04-2014, 12:45 PM   #53
M7H
M7H's Avatar
I just checked, and a 22T will also fit, but then you have to modify 1 of the motor mount bottom screws.
Serpent
Old 11-04-2014, 02:48 PM   #54
BIBOY's Avatar
What pinion is included in the kit?
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
Old 11-04-2014, 06:19 PM   #55
i got a 14T pinion with kit
jeff_78 is offline   Reply With Quote
Old 11-06-2014, 12:42 PM   #56
BIBOY's Avatar
thanks
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
Old 11-10-2014, 11:08 AM   #57
BIBOY's Avatar
Default All set
Got it done here is my set up for now still have get new batteries and new servo
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
Old 11-10-2014, 04:04 PM   #58
fab888's Avatar
did some of you already try to install the transponder ? where do you put the carbon holdder compared to the 977 GP as there is the Lipo ....
thxs
fab888 is offline   Reply With Quote
Old 11-13-2014, 02:25 AM   #59
Hi i am looking at getting one of this cars, im used to running 6s on my gt....i ripped a lrp rotor to shreds....
so i doubt i would be doing 6s anytime soon....so my initial setup would be 4s....lets say i use a 2400kv up....what gearing would i use? i saw someone gave some great advice saying that he used 16-18t.....but what would happen if i went higher? excessive heat or heavy lipo drainage? i need a fast car to get my thrills. but ive blown a few motors and its pretty pricey....If i do this i want to buy what i need one time and cry n a corner with buyers remorse later....
So what would my shopping cart be?
977e,
wheels,
body,
viper esc and 2700kv combo,
gearing/ 16-18t?
and what else??
a spare set of belts?
Im in SA so importing stuff takes a while so i dont want to get stuck...
Reaper1ct is offline   Reply With Quote
Old 11-13-2014, 03:26 AM   #60
dont be afraid of 6S. it doesnt have to mean faster, more volts just means less amps which is cooler and therefore efficient and capable to deliver more power.
so if you are considering 4S with 2400kv you might get more run time and cooler temps with similar power running 6S and 1600kv. both would use the same gearing. id select 19t to start with.. for my track with me driving.. but you might want to check the 977e calculator.
im using 1800kv speed passion motor on turnigy 150a esc with 17t pin and 6S...its great.
BTW the transponder is stuck to underside of servo.
