cutting canber for pan car on carpet
#31
It was the only thing I hated about carpet oval racing.
#32
I cut the inside to the same dimension as the other tires, so if you are running 2.10, I would cut the inside to 2.1 and the outside is larger.
#33
Thanks for the reply Slotracer 577. My test tires turned out right. John
#34
I think in part this works for R/C Oval because of the Foam Tire characteristics
#35
I always cut camber in the fronts on my carpet oval cars. Also add stagger in the front and rear as well........
#36
I cant say I understand why you guys do this.... Most of my experience is on cars and karts but it seems to me if you cut you tires to sit flat with the car at static load then you are in effect canceling any camber you have dialed into your suspension. For a flat track you will want to see the outside edge of your rf tire off the ground when the car is sitting still. When you go into the corner and load up the rf it will sit flat. Again not much experience with rc oval, this all comes from full size cars and go karts.
