Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-10-2005, 07:10 AM   #1
Default brakes engaging when on full throttle
I have a Mugen MRX 3 and for some reason when I'm on full throttle the brakes engage fully. It appears that when I put the car in full throttle, the pin and engages the brakes is turning also and engaging the brakes. The pin isn't turning in the same direction as it does when the brakes are applied, but rather it seems that when there is throttle input, the pin is turning to much in the opposite direction causing the brakes to engage. Does anyone have any recommendations to fix this?
Illusion-Lighti is offline   Reply With Quote
Old 07-16-2005, 05:21 PM   #2
SRAD's Avatar
Default RE
Hello.....check your brake cam post and/or your brake linkage.....something must be binding to cause this. I have 3 of these cars and have not seen nor heard of this problem. Also make sure your brake plates are free on the 2 pins that go through them. Good luck.
SRAD is offline   Reply With Quote
Forum Jump
throttle/brakes question... newb ;P MackIntheBox Rookie Zone 5 10-16-2007 08:20 AM
good analog servos for throttle/brakes (1/10 - touring car) RevMaxx Ask Hitec 1 03-23-2007 04:20 AM
full throttle cut out lowndsie Electric Off-Road 4 05-12-2005 01:50 PM
full throttle btuner Electric Off-Road 3 04-02-2004 09:17 AM
car going to the right when going full throttle alucard13 Nitro On-Road 14 05-08-2003 01:38 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
