Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Losi Desert Buggy XL 1/5th Scale RTR >
Old 01-24-2015, 11:56 PM
  #301
MeatheadRC's Avatar
Building a racer for this summer.Received my shocks today and pulling them apart to go through for "peace of mind".I found limiters on my shock shaft after pulling the boots.Dont see them in the manual.You RACERS using em?Any setup suggestions on shock setups?Im going to put 35wt in front and 30 rear w/DDM springs.what are characteristics in handling compared to my 5ive?Anyone use those aftermarket drive shafts?Any suggestions from trck goers would be greatly appreciated
MeatheadRC is offline
Old 01-31-2015, 01:24 PM
  #302
respirologyrc's Avatar
Freshly painted dbxl
Attached Thumbnails Losi Desert Buggy XL 1/5th Scale RTR-image.jpg
respirologyrc is offline
Old 02-08-2015, 02:58 PM
  #303
blktransam's Avatar
Trader Rating: 59 (100%+)
Anyone just install a big bor kit instead of a complete engine??
blktransam is offline
Old 02-08-2015, 03:21 PM
  #304
Trader Rating: 53 (100%+)
Any one else spur gear not true? Mine wobbles. I'm trying to figure out why this is.
CarFanatic is offline
Old 02-12-2015, 11:07 AM
  #305
MeatheadRC's Avatar
i am putting a dbxl together and my spur is a little wobbly also.hopefully its not an issue.
Old 02-12-2015, 12:46 PM
  #306
.AJ.'s Avatar
I'm picking one up on Saturday, going to be my first 1/5 Petrol RC, can't wait
.AJ. is offline
Old 02-17-2015, 12:52 PM
  #307
.AJ.'s Avatar
Been busy with my truck
.AJ. is offline
Old 02-24-2015, 08:20 AM
  #308
DDMSteve's Avatar
That is looking good; slow transformation into a 5IVEBXL? It is definitely wanting a tuned pipe.
DDMSteve is offline
Old 02-24-2015, 08:32 AM
  #309
.AJ.'s Avatar
Yep, just ordered a Samba
.AJ. is offline
Old 02-24-2015, 01:52 PM
  #310
yup, normal. Had one that was way out of wack, horizon sent me a new gear, same issue. I sanded down the plastic case till it was good and flat, that helped a little. Just a little wobble in it now.
Old 02-25-2015, 06:07 AM
  #311
.AJ.'s Avatar
Samba arrived today
.AJ. is offline
Old 03-01-2015, 06:00 PM
  #312
Looking for some setup info, just bought a dbxl and need to go through it. I'm looking for info on diff and shock fluid. Any help would be appreciated. Thanks
gearit is offline
Old 03-02-2015, 10:21 AM
  #313
Originally Posted by .AJ.
Samba arrived today
...............You will love that Samba!! I put one on my 30cc OBR LR Reed and it brought it to life!!!
nitrohead5300 is offline
Old 03-05-2015, 09:07 AM
  #314
MeatheadRC's Avatar
I am building a racer for the track this spring so this is not a tested setup but will repost after findings.This setup I used on my 5ive and seemed to work well.I have 35wt in front shocks and 30wt in rear/with the stiffer DDM springs.I have 5000wt diff fluid in center and front diffs w/3000wt in rear.I highly recomend team fast eddy bump stop screws to protect your chassis from your droop screws.They almost dug all the way through on my 5ive until I installed them.GOOD LUCK I will post my findins after a day at the track(wont be for a couple months we still have snow on the ground)
Old 03-05-2015, 10:39 AM
  #315
.AJ.'s Avatar
It's done the same to the stock 23cc motor as well
http://youtu.be/lnBnrs7WzkE
My mates can't believe its a not a bigger motor lol
.AJ. is offline
