which 2 cycle oil should you use??
Which type of 2 cycle oil should you use in a 2 cycle gas motor?? Some people say caster based 2 cycle oil , some say synthetic and some reccomend non synthetic. I am confused. I was told that synthetic oil does not allow the ring to break in and caster based oil carbons up the motor !! So which camp is correct??
Oil
Castor is a good oil to use. The best would be a class 5 synthetic but it's pricey.I use blendzall green label castor. It does leave carbon but it wont hurt anything except the plug may need changed once in a while.Steer clear of any synthetic oil less than class 5 as it doesn't lube a 2 stroke as well.
I run just two stroke marine oil in my racing boat, its like $6 a qt.
Then use whatever you want.
Thanks for sharing your opinions and experences with 2 cycle oil.
