Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Old 08-19-2013, 01:52 PM   #1
Default SC10.2 dirt oval setup
Looking for a setup that will work on a dirt oval for my 10.2 I have the gearing figured out, was wondering if anyone can post a setup. Thanks
RedFormula2K is offline   Reply With Quote
Old 09-08-2013, 12:30 PM   #2
I have a sc mod and ran it for the first time. I put 50wt shock oil all the way around, and used front springs front and rear. Not sure of the colers but was the two stiffest springs they make for big bores.
RONNIE C is offline   Reply With Quote
Old 09-08-2013, 12:44 PM   #3
MasterTech's Avatar
Not running an sc10 myself, but I have noticed that there seems to be a difference in setups between mdm and late model bodies. What type of body are you using on yours? Are you using a ball diff? Made a big difference in a good way on my outlaw mdm chuckworksrc slash. It drifts off the corners in a controllable way now. If you are using a gear diff and some decent brushless power, make sure the gears inside the diff are shimmed properly or you will start hearing some clicking noises before the gears go. I did witness that on our local track.
MasterTech is offline   Reply With Quote
Old 11-26-2013, 07:28 AM   #4
softest spring you can find in the right rear a mid in the left rear and right front soft left front
40wt left side
60wt right side
thats wha ti run in my mod works great for me
sammy745 is offline   Reply With Quote
