Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Fg stadium truck (modellsport) >
Old 12-23-2012, 03:13 PM
  #16
check for air leaks around carb area. if not the carb may be gummed up and needs to be cleaned. The bog out is the clutch starting to grab because of the high idle. The clutch grabs which slows the rpms just enough to make the clutch let go, idle shoots back up and it grabs again.
Make sure your throttle servo isn't part of the problem seeing you don't have a radio to turn on and center everything.
Depending on the phone if you turn it on it's side you will get a wider vid.
royrp is offline
Old 12-23-2012, 03:15 PM
  #17
nhmade's Avatar
Trader Rating: 54 (100%+)
did you disengage the throttle from the servo...?
nhmade is offline
Old 12-23-2012, 03:17 PM
  #18
Trader Rating: 3 (80%+)
I dont have a radio right now so im not using the servo i throttle it through the carb. But thTs not the problem even if i give it throttle it just bogs out and wants to stall.
Rcjunky2002 is offline
Old 12-23-2012, 03:29 PM
  #19
check all your fuel lines. Do you have a filter in the tank? With it running get a can of wd-40 and spray around the gasket area if there is a leak you'll know.
royrp is offline
Old 12-23-2012, 03:32 PM
  #20
Ok thanks il try that. Someone told me it might be too low on fuel. It only had enough to start it. Im gonna start out by cleaning the carb and put new fuel lines
Old 12-23-2012, 04:39 PM
  #21
Have you tried to run it as in your video without the gas cap tightened? It could be vacuum in the tank causing this. Also check the fuel lines to see if they has been mixed up, the bottom one on the carb should be the one with filter/clunk on in the tank. Also try start gas and spray it around the carb and the gaskets with the engine running to see if the idle picks up, if it does you have a leak somewhere.
Lars in Norway is offline
Old 12-23-2012, 04:41 PM
  #22
Thanks guys. I am out of town till after xmas but i wil def try these things when i get back. I will keep posted
Old 12-25-2012, 09:16 PM
  #23
Alright guys just thought id update the status of the fg. The was a pinch in one of the fuel lines and it was starving for fuel. Must of been when i removed the rollcage to clean it when i zip tied the fuel lines to the cage i must have crimped the line too tight. Thanks for all your help
Old 12-26-2012, 06:00 AM
  #24
glad it was something simple.
royrp is offline
Old 12-26-2012, 06:10 AM
  #25
hotrod87's Avatar
Trader Rating: 252 (100%+)
Always nice when it turns out to be a simple fix.
hotrod87 is offline
Old 12-26-2012, 04:03 PM
  #26
Yep, nice to hear you got it sorted out
Old 12-26-2012, 10:20 PM
  #27
Couldn't of done it without you guys's help
Old 12-27-2012, 04:11 AM
  #28
hotrod87's Avatar
So are you gonna keep it and run it now? You should, their a blast.
hotrod87 is offline
Old 12-27-2012, 07:14 AM
  #29
It might be sold. Not sure yet tho. I really want somethig i can run indoor and outdoor but i really dont wanna sell the fg if i dont have to lol.
Old 12-27-2012, 08:34 AM
  #30
hotrod87's Avatar
Don't do it. LOL
hotrod87 is offline
