Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-26-2005, 11:42 AM   #1
rcinsight's Avatar
Cool 1/10 Pan Car Set Ups
After running my first Club Race with my RC10L4, with my Rookie Stripe and keeping up with the Big boys I'm hooked.
All I can say is what was I thinking starting out with a Touring Car?
I can hardly wait for next year when I will be running stock brushless. Maybe a Neo One?
When setting up my car, I used the Asphalt cheat sheet on the back cover of the manual.
The only variances I used to differ from the 2002 AE Pro Driver's set up was a #1 piston on the Macro shock, Green Jaco's on the left wheels, Blues on the right, Aqua on the RF, 1 degree camber on the fronts, stock front springs,2 bolt t-bar. Running Stock motor.
Are there any current RC10L4 set up sheets on the web or how people set their cars up? What about a website for People size racing car set ups?
I was told my car drove smooth through the carpet wrinkles and handled well around the turns.
Since I placed in the middle of the pack each time (2nd in my first heat), I don't want to tweak anything major and just concentrate on maintaining my line.
rcinsight is offline   Reply With Quote
Old 03-27-2005, 03:15 AM   #2
rcinsight's Avatar
bump
Old 03-31-2005, 03:25 PM   #3
rcgen's Avatar
Go to the ae website and checkout setups. I basically followed Sean's setup and adjusted for the local tracks I run. It's a good starting point
rcgen is offline   Reply With Quote
Old 04-01-2005, 10:43 AM   #4
rcinsight's Avatar
Thumbs up
Thanks.
It was Sean Daryl's setup that I used as a starting point and changed small things from there to work on carpet.
Sounds like I'm there and need to work on choosing my line, better.
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
