Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-10-2005, 02:30 PM   #1
Default Silva Ride
WHAT DO YA THINK SHOULD I MOVE THE ELETRONICS OVER AS WELL?
pony klr is offline   Reply With Quote
Old 03-13-2005, 10:36 AM   #2
Trader Rating: 15 (100%+)
Send a message via AIM to microrcdude
Why the internal intenna?
-Kyle Keenan
Contact me for Vinyl Sheets to protect your chassis.
microrcdude is offline   Reply With Quote
Old 03-14-2005, 03:25 AM   #3
the antenna outside the car just makes more drag in the air
UPDATE my silva car went 1 lap faster than my old personal best! and i did it with 8 cars on the track!
Old 03-23-2005, 08:56 AM   #4
Send a message via AIM to xfactor70
hey pony i would mount all the electronics on the left side of the car. not sure what speedo u run but the Q2 fits perfect in front of the left rear tire. place the recevier about an inch to an 1/2 off of the edge of the chassis. This is how most of the team guys run there cars with awsome results.
Ritchie Mac
Silva Concepts
PRS
KCR
Murdock R\C
Dankim Graphics
IRS
xfactor70 is offline   Reply With Quote
Old 03-24-2005, 05:55 AM   #5
already did it gained i more lap thanks!
Old 03-26-2005, 08:17 AM   #6
David Butts's Avatar
Send a message via AIM to David Butts
Default Thats a drag.
All though I too run an internal antenna more for looks than anything. If the antenna tube created so much drag dont you think they would lay down at speed? Even at our track which is huge and the cars are cruising, Guys who run the tube routinely have them whipping the loop bridge at full throttle down the front straight.
Oh my!
From way up yonder in Middleburg
David Butts is offline   Reply With Quote
Old 03-31-2005, 12:29 PM   #7
ovalnator's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to ovalnator
less chance for interference by running the tube outside the body
www.redneckrc.com
ovalnator is offline   Reply With Quote
Old 03-31-2005, 01:41 PM   #8
I DISAGREE IF IT DOES NOT GLITCH then why have it up there whipping around tranfering weight ?
Old 03-31-2005, 01:53 PM   #9
17driver's Avatar
R/C Tech Charter Subscriber
Outside I usually run the antenna outside,indoors I always run it inside the body.Now I have the Spektrum so I will be running the atenna inside.
Midwest malitia member Got NI-MH?
17driver is offline   Reply With Quote
Old 03-31-2005, 02:06 PM   #10
ovalnator's Avatar
your talking about something that doesnt even weigh an ounce. The weight transfer is non-existant. Unless your running the spektrum or PCM receiviers, then you should have the antenna outside the body, as FM and AM are more prone to interference.
www.redneckrc.com
Old 03-31-2005, 03:10 PM   #11
I've run pan cars with am and fm radios on oval with a 320 foot running line for years with the antena inside the body without a glitch problem
SCOTT HOWARD is offline   Reply With Quote
Old 04-03-2005, 03:45 PM   #12
burbs's Avatar
Location: HERES A NEW IDEA, I'LL GET YOU A SPOON, SO YOU CAN EAT MY @SS
Send a message via AIM to burbs Send a message via Yahoo to burbs
there si no advantage to running it inside or out. it will not drag or cause any performance changes... it is more likley for someone to get a glitch inside then out,,, but both work... we run on a 365 runline track.. ive run it in the body and out. both in the same day with the same setup, and there was no difference.. preference is all it is..
HERE IS MY TRADER FEEDBACK ON HOBBYTALK.
http://www.hobbytalk.com/bbs1/traderratings.php?u=8257
burbs is offline   Reply With Quote
Forum Jump
Silva X-Factor jt6 R/C Items: For Sale/Trade 6 09-05-2008 04:11 PM
Awesome TC4 and RC10L4/Silva oval Paul S R/C Items: For Sale/Trade 0 03-20-2007 05:48 AM
Silva Concepts X-Factor 4 Brian Anthony R/C Items: For Sale/Trade 0 05-11-2005 01:06 PM
Silva concepts web site! Monti Electric On-Road 3 01-25-2005 10:20 AM
Silva Shocks rayhuang R/C Items: For Sale/Trade 3 10-29-2003 04:34 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
