Axle/Extention
Axle/Extention
I have a body which is wide and tyres are too deep. I want the tyres in line with the body. I need at least an axle size of 73-75mm but the longest I can find is 66m
The existing axle is 8mm diameter 57mm long and will fit 17mm Hex tyre with an adapter
See my axle picture
Can anyone help with a suggestion of getting any extenders etc
Many Thanks as ever
See my axle picture
Many Thanks as ever
FG makes an extended front axle # 8466 , 65mm long. , you will probably also need the wider square wheel driver # 06107/01 it's about 17 mm wide ,vs 9.5 , or double up on the stock square hubs @ laregescaler site_JH
Hello jhiggins
Thank you for your time to reply. I did think FG8466 but I need an axle upto 75mm- It will be difficult to find one
Thanks again for your feedback
