Need help setting up FG F1
Hi guys,
I have FG F1 Sportsline and I need help setting up the suspension.
Do you mind sharing your suspension setup so I can use it as a baseline?
I run this car at GLARC in LA.
Right now here is how I setup the car:
Front setup:
Tires: Roadies
Camber: - 2.5
Toe: Out 1 degree
Ride Height: 8 mm
Springs: Yellow progressive
Oil: 2000
Stabilizer bar position: middle holes
Rear setup:
Tires : Roadies
Camber: -1
Toe: In 2 degree
Ride Height: 10 mm
Springs: Red
Oil: 2000
Stabilizer bar position: Top holes
Differential: FG Viscous Diff w/ Mobil 1 75w/90 differential oil
I haven't tested this setup yet so I don't know how this setup will work at GLARC, but I want to see how people setup their F1 for GLARC.
Front setup:
Tires: Roadies
Camber: - 2.5
Toe: Out 1 degree
Ride Height: 8 mm
Oil: 2000
Rear setup:
Tires : Roadies
Camber: -1
Toe: In 2 degree
Ride Height: 10 mm
Springs: Red
Oil: 2000
