Fusion Batteries Oval Discussion
#46
New developments at Fusion. If you would like to try our loose cels they are now available to the public.
John
John
#50
k/n winterblast
team fusion was well represented in the A-main stock and 19T 1/10 oval with jason lambert running a close second in both races.with a car i set up for flat track and a class i dont run i ended up 2nd in the C-main which was great for me .FUSION batts supplied more then enough voltage and run time for us.I'm not sure what other fusion drivers were there was very busy racing and watching the snow storm.John,Judy<and jeff keep up the GREAT work .John and Craig Marsh
#52
Greetings Fusion drivers looking for a little assistance on an L4 set up for asphalt oval the runline is 375' Currently have the following on my car
Wolf hinge pins with red standard springs
R/R Red with 30Wt oil
R/L Blue with 30Wt oil
C/Green with 60Wt oil
Green foams front and rear
.5 toe out
Camber L/-2 R/0
64P 110t spur/37T pinion
19T chameleon 2 Pro (have a new Arconite as well)
I have never raced oval before and been running touring and am going to start just wanted some opinions on set-up gearing will be using 4 cell 3300s. LMK thanks
.5 toe out
Camber L/-2 R/0
#54
Dan or Rich please try to help this man. I am not an oval racer so I cant be of much help with his setup questions. Sorry gene I will get you some help asap. Thanks
john
john
#56
.5 toe out
Camber L/-2 R/0
.5 toe out
Camber L/-2 R/0
#57
SNOWBIRDS IS "OVER"
Well,the 2005 Snowbird Nationals are in the books!
And what a week of racing it was!!!!!
Had a great time racing,and meeting alot of new guys,and John for the first time.
Man,I had an awesome open mod car!!!!Turning the same lap times as the BIG DOGS!!!!
But,I must have had the gearing a little off!!!!!
And to top it all off,I had to leave early on main day!
Had a family emergancy back home.But the fusion power was good!!!
Next Big OVAL event is March 17-20,in Daytona FL!!!!
It is called the SPEEDWAY SPECTACULAR!!!!!
It is an awesome track,they build a huge @ 400' track at the entrance to pit row,in the Daytona speedway!!!!!!!!!!!!
Looking forward to some redemption!After the Snowbirds !!!!!!
John says that FUSION has some "KILLER"cells right NOW!!!!!!
So you guys better get them ,Before your competition does!
#58
I just returned from a long road trip from nothern Utah to Southern California where I partook in my very first dirt oval race in the 1st annual Desert Dirt Oval Championship. Where I took 1st in the 2WD Stock A-Main. And I also took 6th in the Expert Stock truck after a bad pile up in the opening lap. There were a total of 123 entries at the event. A special thanks goes out to Fusion for their supierior batteries.
#60
cant wait to get back to P'cola. I raced over a hurricane in mobile but have been out in california for the last year racing. Hope to be back there in a couple of weeks. If you see a white f-150 with an enclosed white trailer at the track. Come over and say hi.
