New to 1/5 BAJA 5B/5T HELP THREAD
EVERYTHING 1/5 BAJA 5B/5T/sc HELP/Mod/Build THREAD
I am sure there is some "GENERAL" Baja thread, but I personally been having specific questions as I been moving along with my BAJA 5B and have been posting them on some other guys QUESTION thread. So here is my personal thread... But ANYONE is able to jack it with questions, tip or advice of there own that would help ANYONE with a BAJA.
NEW QUESTION...for me at least I am in the process of tearing down my BAJA to do a stroker kit to 29cc...But in fact, I just found out the kit I purchased will ONLY give me 28.5 since its just the head stroker and NOT the full stroker kit with stuffed crank. So, now that I have this BRAND NEW IN THE BOX...I am thinking of going a whole different route. I can either just buy the stuffed crank to complete a 29cc kit or "GO BIG OR GO HOME"to a Bigger STROKER KIT to 30.5cc (1 of 2 Part#'s cc253+dd312 or cc253+dd308) Does anyone know the exact difference between these two,advantages from to another, do's and don'ts, warnings or go for it!!! ? Anything would help from someone who is quite knowledgable in this area. The only difference I see in the descriptions on DDM is cost! And last, does anyone know how difficult installation of these kits are to someone who have just above medium knowledge of general engines. Thank You so much!
there is info out there for large scale you wont find much here .or it will take awhile for someone to respond .
Here is a good thread post from another forum
http://www.bajaaddicts.com/showthread.php?t=6911&page=2
it may not work till you sign up
or try this one
http://www.wiseco.com/Calculators.aspx
lots of info out there just have too look around an do some reading.
or try this one
here you go from some of the discussion.
[quoted from biggiecamp]
[By that theory it would be a 27.4 with +2mm stroker crank instead of 27.2
The displacement isn't alway a direct addition. There's a formula for it. One of these guys probably knows it.
34mm jug (stock 26 cc) with....
stock crank =25.4
+1 crank = 26.3
+2 crank = 27.2
36mm jug with.....
Stock = 28.5
+1= 29.5
+2= 30.5]
stock crank =25.4
+1 crank = 26.3
+2 crank = 27.2
36mm jug with.....
Stock = 28.5
+1= 29.5
+2= 30.5]
Ummmm yeah, Being that I am on the NEW side of things regarding fuel powered RCs... Not sure what that all means... But to play it safe, I may just do what is best of BOTH worlds and reliable... Part #dd310 Stuffed crank already purchased part #ca370 ... I actually thought the STOCK 26cc was quite nice... Fast and good TQ... So, I may just bump it it a notch just for the hell of it... Just wondering if anyone has had any experiences or tech notes/advice. I also noticed doesn't seem to be too many Baja or 1/5 alike here... Seesm to be more directed to touring and off road 1/10-1/8 scale... Which is cool to! I just don't have too many questions right now in those categories...
well your 25.4 is your 26 with stock crank/26.3 + 1mm stroke/27.2+ 2mmstroke
36 mm is your 28.5/29.5/30.5 with the diff stroke for diff folks .lol
the only problem with this is head clearnace shimming ect. most often you can get a long block from a engine builder just as cheap or a few bucks more an us you pieces to run it.
heres a link to dog pile racing good products.
http://www.dogpileracing.com/scripts...?idCategory=24
With the kit I am looking to complete ca370 + dd310 is there a significant difference from stock? And what way? Both Top speed and tq? or one of the 2?
sounds like a plan .
I hope I helped a little .just didnt want to see you get the wrong combo of parts.
I did see some ported options offered at ddm an largescale rc.
the long blocks are a good way to go .my next engine is going to be the 29.5 version in a long block. there a many guys running dpr mills and are vary satisfied an have bought seconds.
good luck a keep us posted on your project.
I just found out I have been calling it the wrong thing , so I just wanna correct my verbage. I don't have a "STROKER" kit... What I have is a CONVERSION kit... Pretty much modded stock parts just bumping up the compression to 29cc or in fact as the charting goes above 28.5... So a conv kit is cool with me From what I was told from someone who did the same thing locally is: "You will notice the difference BIG TIME in my "ROKKIE BAJA EYE AND FEEL!" ~ It will RIP! Shhhhhhhooooot! I was HAPPY with the stock cc's and performance
Either way u cut it... 26cc to 29cc is Nice Its will be the same as if swapping the motor from a 23cc to the SS 26cc... I am sure someone here knows what I am talking about and can relate... NEXT TIME, I will just buy a entire built motor combo = $450~500 ish...
Finally, moddin and build has started...Again Tell u what, I am getting pretty dam familiar with this car back to front... Here is a few phone pics and more to come along the way and progress.
THIS IS PRETTY MUCH HOW I STARTED...Just NOT as clean
Then... THE TEAR DOWN...
Oh YEAH... U see it!!! "HERE WE GO!!!" I was on my 4th during this time of disassembly
Yeah... That is NOT what u think!!! LOL...That came from under the motor and tank...LOL!
Whats NEXT!!!
More to come.............................................. ...
Whats NEXT!!!
Whats NEXT!!!
Whats NEXT!!!
wow a lot of nice goodies you got yourself there
well... since my last post or update, here is the most recent pics of my progress of my build. As seen in pics above, I installed the NEW Dom V2 pipe, Walbro #813 (chokeless) carb, 29cc Conversion, MSD Plug w/TAYLOR 8MM wire, TEAM CHASE Shock Tower risers, TR HD Clutch System, Cage risers, ATC H-Bomb support & quick cage release kit and iNTEGY front disc brakes. Since the pics were taken, some parts needed a lil tweeking here and there for proper fitment and function.
