Tyre Additives
Tyre Additives
Hi all, can some some give me some help with tyre additives, I have got back inot racing and have a mardave V12, running really well now but have been recommended to use tyre additives to gain grip in the corners.
Can anyone recommend any?
Ive seen this but ive never used additives before.
http://demonpowerproducts.co.uk/prod...oducts_id=5664
Can you help please.
Forgot to add im using foam tyres.
Anyone got an opinion ?
Hi thanks for the reply, it's on carpet indoor and not sure if there is a restriction on odur.
During the ETS and last club race i used corally CarpetJack. It gave me more traction then jack the gripper and is also odorless. The tires also get softer so for consistency sake better run every heat and final a different set of tires. (3 heats and 2 finals is 5 sets of tires). In the end it saves you money as the wear is way less then when driving one set of tires for the whole day. (one set of tires get softer after every run, so les consistent and more prone to wear).
